Brake Proportioning Valve & Metering Valve ??? #3156154
07/02/23 10:42 AM
07/02/23 10:42 AM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
Going to replace my Valves with new, so what experience have you had ? Any "Brand" better than the others ? This is on my '70 T/A , disc in front, drums rear, power brakes. Thanks, Kevin
Re: Brake Proportioning Valve & Metering Valve ??? [Re: B5TA] #3156180
07/02/23 11:49 AM
07/02/23 11:49 AM
MD
floyd Offline
floyd  Offline
MD
I have no personal experience with the repros but have read here and elsewhere about leakage with those. You can get you originals rebuilt at Brake & Equipment Warehouse in MN. I had mine done there.
https://brakeandequipment.com/machine-shop/
Re: Brake Proportioning Valve & Metering Valve ??? [Re: B5TA] #3156236
07/02/23 02:25 PM
07/02/23 02:25 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
1st thing to establish is whether it is a proportioning valve or PRESSURE DIFFERENTIAL valve. The PD valve does nothing more than turn on the brake warning light if there should be a loss of pressure to 1 side of the system.
This is a common misconception that started many years back wink
Re: Brake Proportioning Valve & Metering Valve ??? [Re: TJP] #3156427
07/03/23 08:32 AM
07/03/23 08:32 AM
VA
dragon slayer Offline
VA
He posted Meter and proportion, so that would be disc set up 70 up B & E though other models may have used it too. Meter holding off pressure to disc and proportion to limit pressure to rear drum. The distribution block/Dp brake warning is the 3rd and always present piece. Mopar did start to combine the valves into 2 and than1 piece later.
Re: Brake Proportioning Valve & Metering Valve ??? [Re: dragon slayer] #3156493
07/03/23 11:13 AM
07/03/23 11:13 AM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
Man , I'm getting a Head Ache trying to figure this out . I've found them priced any where from $45.00 - just under $200.00 Hard to figure where the Quality comes into play. what do you guys think ????? Thanks , Kevin
Re: Brake Proportioning Valve & Metering Valve ??? [Re: dragon slayer] #3156507
07/03/23 11:48 AM
07/03/23 11:48 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
You are correct sir, i blew by that spank spank beer
Re: Brake Proportioning Valve & Metering Valve ??? [Re: TJP] #3156813
07/04/23 09:36 AM
07/04/23 09:36 AM
Minn
SportF Offline
SportF  Offline
Minn
This is also the valve that cuts off the low pressure (leaking) side. This is the valve that gives you the dual safety factor. Without it, you don't have a dual system.
Re: Brake Proportioning Valve & Metering Valve ??? [Re: SportF] #3156853
07/04/23 12:27 PM
07/04/23 12:27 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Actually the master is where the dual braking comes from. Lots of vehicles built without the differential valve. The differential valve usually activates a light and some cut off flow to the leaking side, but not all.
Angry white pureblood male
Re: Brake Proportioning Valve & Metering Valve ??? [Re: ruderunner] #3156892
07/04/23 02:30 PM
07/04/23 02:30 PM
Minn
SportF Offline
SportF  Offline
Minn
No, no that is not true. That is what almost everybody thinks, but its not true.,. Do this, you got no shuttle valve? Open a bleeder and the pedal will go to the floor. If you have dual system, why will it do that? Its because you have no dual system. Maybe you've already bleed the brakes....what happened....the pedal goes to the floor. Actually, even with a shuttle valve it will go to the floor. You got to stab the pedal, get the shuttle valve to shift, light comes on, and the low side is sealed, pedal stops.
Re: Brake Proportioning Valve & Metering Valve ??? [Re: SportF] #3156957
07/04/23 04:26 PM
07/04/23 04:26 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Incorrect. The pedal will not just go to the floor. It takes up the slack in the master (the pistons butt together) then builds pressure in the non leaking side.
Longer travel? You betcha but it will build pressure in the sealed side and stop the car.
Got a single master? Crack a bleeder and tell us what happens.
Re: Brake Proportioning Valve & Metering Valve ??? [Re: ruderunner] #3157451
07/06/23 09:50 AM
07/06/23 09:50 AM
Minn
SportF Offline
SportF  Offline
Minn
1967
1sr engineer: Hey look, I designed a brake valve block so that when a lower pressure or leak occurs, this piston slides over and lights a light!
2d engineer: Hey good. But, when the piston slides over, why don't you have it cut off the port to the leaking side. That way you'd have a safety factor.
1st: I can't do that.
2d: Why not?
1st: Because 50+ years in the future, a guy on the internet is going to say that isn't how its supposed to work.
2d: What is the internet?
1st: I don't know, but I think in the future, those folks will be smarter than us.
Re: Brake Proportioning Valve & Metering Valve ??? [Re: SportF] #3157455
07/06/23 10:03 AM
07/06/23 10:03 AM
VA
VA
If the distribution block sealed the low side to stop the leak, how would you bleed brakes? The Master training goes through this dual MC pretty well, the pistons do have tail piece to allow for direct contact to keep front and rear isolated in the case of a bad leak.
Re: Brake Proportioning Valve & Metering Valve ??? [Re: SportF] #3157460
07/06/23 10:14 AM
07/06/23 10:14 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Originally Posted by SportF
1967
2d: Why not?
You've never studied how a dual master works have you?
Re: Brake Proportioning Valve & Metering Valve ??? [Re: dragon slayer] #3157461
07/06/23 10:15 AM
07/06/23 10:15 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
This.
Re: Brake Proportioning Valve & Metering Valve ??? [Re: ruderunner] #3157465
07/06/23 10:39 AM
07/06/23 10:39 AM
Minn
SportF Offline
SportF  Offline
Minn
It takes a sharp pressure spike to set it over. Just take a look at your valve block, look at the front lines. You can SEE that the piston will cut off the ports just the way the lines are on there.
But, I give up, you guys have dual brakes no matter what. One question, when you bleed your brakes, did the pedal go to the floor? I'm outta here.
Re: Brake Proportioning Valve & Metering Valve ??? [Re: TJP] #3157469
07/06/23 10:44 AM
07/06/23 10:44 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
He has a 1970 T/A, so all of them had the 'new' setup that entered use on Jan 1, 1970.
There is a two page TSB about it and how it functions at https://www.hamtramck-historical.com/images/TSBs/1970/D70-5-1%20page1.jpg and https://www.hamtramck-historical.com/images/TSBs/1970/D70-5-1%20page2.jpg
Re: Brake Proportioning Valve & Metering Valve ??? [Re: SportF] #3157506
07/06/23 12:19 PM
07/06/23 12:19 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
No, it doesn't go to the floor, it takes up the slack I the master, the pistons butt together then the master builds pressure in the other half. Ever bench bled a dual master? You can see it happening.
Think about this, if your magic valve is so great, why wasn't it ever used with a single master? What happens if the line from your single master to your magic valve fails?
I guess the millions upon millions of vehicles sold that don't have the valve are all in violation of federal law? Better get a lawyer and make it rich!
Re: Brake Proportioning Valve & Metering Valve ??? [Re: ruderunner] #3157973
07/08/23 09:23 AM
07/08/23 09:23 AM
VA
VA
This is the definitive training answer to explain it. From the 67 Master training. Unfortunately, the slide show link doesn't work, but watch the film movie. MC covered first, distribution block around 11m 27 sec. It clearly shows how the port does not close. The barbell shaped warning light trigger does not move far enough to close the outlet ports because of the warning light stud stops it.
https://www.web.imperialclub.info/Repair/Lit/Films/232/
Re: Brake Proportioning Valve & Metering Valve ??? [Re: dragon slayer] #3158018
07/08/23 01:01 PM
07/08/23 01:01 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Stuff changes. From the 73 FSM, when talking about pressure bleeding the brakes it states the following.
Re: Brake Proportioning Valve & Metering Valve ??? [Re: Sniper] #3158887
07/11/23 05:11 PM
07/11/23 05:11 PM
Minn
SportF Offline
SportF  Offline
Minn
You mean the tech manual says the valve closes off flow? Gee, it must be wrong, eh?
