Size of the screws that hold the incert into cuda hood #3156141
07/02/23 09:47 AM
07/02/23 09:47 AM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
I been piece togeather a old rally cuda hood I bought pretty cheap while back
When bought it only had one bezel
So I have bought a bezel. And then bought a pair of fin incerts for those
So now I need some screws attach the incerts
The incerts have 2 screw holes and 2 studs(wich don't ever look to had any threads)
So where can I get what is needed to mount the incerts
Or what length and size(machine screw?) Would been used
Tia
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Size of the screws that hold the incert into cuda hood [Re: toplescuda] #3156148
07/02/23 10:29 AM
07/02/23 10:29 AM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
This picture should explain a few things.
Re: Size of the screws that hold the incert into cuda hood [Re: toplescuda] #3156159
07/02/23 11:05 AM
07/02/23 11:05 AM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
Okay, I found the bag when I bought those well nuts and the note I put inside it. If you can't make out the label it says:
WELL NUT
FOR 5/16 HOLE
#8 - 32 UNC
ITEM NO. C23500
The note I put inside was for the screw size: Head diameter approximately 7/32. Length about 3/4. Threads 8 x 32.
Your other option could be to buy the reproductions by Tony's Parts, they're the 1970 style, and use Pal nuts. You obviously have to take the scoops off install his inserts.
Re: Size of the screws that hold the incert into cuda hood [Re: EW1BH27] #3156214
07/02/23 01:10 PM
07/02/23 01:10 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Similar to '68 RR/GTX hood insert (engine call-out) screws, only longer.
Re: Size of the screws that hold the incert into cuda hood [Re: topside] #3156251
07/02/23 03:09 PM
07/02/23 03:09 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Mine would be 71 and up
1971 charger
Re: Size of the screws that hold the incert into cuda hood [Re: toplescuda] #3156287
07/02/23 05:22 PM
07/02/23 05:22 PM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
Must be a new car, your profile shows only 1970 E bodies.
Re: Size of the screws that hold the incert into cuda hood [Re: EW1BH27] #3156401
07/03/23 05:28 AM
07/03/23 05:28 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
I
Really it's just a rally hood picked up cheep and will later be cutting a hole in for a blower on boys 70 gran coupe
1971 charger
