'69 flashers - round or square ?? #3154497
06/26/23 08:56 PM
06/26/23 08:56 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Got one of each in my harness, which is original - round or square ??
Re: '69 flashers - round or square ?? [Re: Stanton] #3154514
06/26/23 09:56 PM
06/26/23 09:56 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Are you talking about the A01 light package fender (top/front) mounted signal you can see from the driver's seat?
Re: '69 flashers - round or square ?? [Re: Stanton] #3154516
06/26/23 09:59 PM
06/26/23 09:59 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Originals are all round, never saw the square ones until the 1990's.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: '69 flashers - round or square ?? [Re: Stanton] #3154517
06/26/23 09:59 PM
06/26/23 09:59 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Both types were used. Depends on whether used for Turn-Signal or Emergency
Re: '69 flashers - round or square ?? [Re: Stanton] #3154519
06/26/23 10:08 PM
06/26/23 10:08 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Oh you're talking about the flasher RELAY, oops my bad blush
Re: '69 flashers - round or square ?? [Re: A12] #3154528
06/26/23 10:59 PM
06/26/23 10:59 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Round...
JB Rhinehart, Realist
A-Body's RULE!
Re: '69 flashers - round or square ?? [Re: Rhinodart] #3154594
06/27/23 08:08 AM
06/27/23 08:08 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Round. The mounting bracket as I recall will only fit the round.
Re: '69 flashers - round or square ?? [Re: NITROUSN] #3154597
06/27/23 08:12 AM
06/27/23 08:12 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
So, some interesting replies ...
1) Sorry, I meant the relays - but everyone seems to call them flashers.
2) I have one of each square and round - turn and emerg
3) the mounting brackets accept both but fit the square ones better
4)
Quote
this is an interesting statement because I've owned the car since '73, never changed a relay and the car was mothballed in '85. So I'm pretty sure the square one is original.
Re: '69 flashers - round or square ?? [Re: Stanton] #3154603
06/27/23 08:21 AM
06/27/23 08:21 AM
N
NITROUSN Offline
NITROUSN  Offline
N
4)
Quote
The factory parts manual calls them all Flashers. No mention of relay. 3 part numbers.
1-2932877 Most common turn and 4 way all car lines.
2-2932875 Says 2 lamp so it must be light duty.
3-2932876 Looks to be HD police and taxi.
The mounting clip is one number 2770998
Re: '69 flashers - round or square ?? [Re: NITROUSN] #3154613
06/27/23 09:09 AM
06/27/23 09:09 AM
md
mopars4ever Offline
mopars4ever  Offline
md
All those part numbers are round. The 2932875 is blue plastic IIRC
Re: '69 flashers - round or square ?? [Re: mopars4ever] #3154692
06/27/23 01:49 PM
06/27/23 01:49 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
It was more of a curiosity question than anything else. Going to be using some LEDs so need to replace both with electronic. The new ones are all plastic with a ground wire - I assume the originals grounded through the case.
Re: '69 flashers - round or square ?? [Re: Stanton] #3154701
06/27/23 02:18 PM
06/27/23 02:18 PM
N
NITROUSN Offline
NITROUSN  Offline
N
OEM Flasher case does not need to be grounded.
Re: '69 flashers - round or square ?? [Re: NITROUSN] #3154715
06/27/23 03:17 PM
06/27/23 03:17 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Quote
Interesting ... I just looked at the FSM wiring diagrams and sure enough ... no grounds.
Just assumed 'cause some aftermarket units have ground pigtails that the originals were grounded.
Re: '69 flashers - round or square ?? [Re: Stanton] #3154718
06/27/23 03:26 PM
06/27/23 03:26 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Quote
I do not recall ever seeing a flasher that needed a ground with incandescent lighting. LED lighting may be a completely different story.
Re: '69 flashers - round or square ?? [Re: NITROUSN] #3155267
06/29/23 02:26 PM
06/29/23 02:26 PM
moparx Online content
moparx  Online Content
Quote
even the somewhat later model K cars did not use a ground wire on the flasher can[s].
however, when the flasher cans were combined into one [square] unit in [or around] the 96ish [?] model year, using a multiple prong unit, i don't know if those are grounded or not.
i never traced it to see.
beer
Re: '69 flashers - round or square ?? [Re: moparx] #3155268
06/29/23 02:29 PM
06/29/23 02:29 PM
oh, and LED lighting is indeed something different, needing grounds and [sometimes, if not most] needing correct polarity to work correctly.
beer
Re: '69 flashers - round or square ?? [Re: moparx] #3155455
06/30/23 12:07 AM
06/30/23 12:07 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I used a set of these and they are noticeably brighter, I mean like a multiple when viewed against my garage door back to back.
https://www.amazon.com/gp/product/B07PFC1Q59/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I don’t know what flasher my car has, but it still works the same with these bulbs. I’ve read a bunch of posts talking about issues running leds. The first set failed in 00 miles or less and the company sent another one no questions that have held up longer.
I want my fair share
Re: '69 flashers - round or square ?? [Re: SomeCarGuy] #3155491
06/30/23 08:54 AM
06/30/23 08:54 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
The original bulbs in the taillights were clear - are LEDs too bright to use clear? Should red LEDs be used there?
Re: '69 flashers - round or square ?? [Re: Stanton] #3155773
06/30/23 11:37 PM
06/30/23 11:37 PM
SomeCarGuy Offline
SomeCarGuy  Offline
I suppose it would be ok to use clear since the lens will tint it. That company suggested to use red on the brakes and I have to say it worked out. Seeing how much brighter it is let me know it’s worth it. I do carry the originals as spares after the set failed. I’m probably just too paranoid but I carry a trunk full of tools and parts so what was one more little box?
Re: '69 flashers - round or square ?? [Re: SomeCarGuy] #3155848
07/01/23 09:41 AM
07/01/23 09:41 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Quote
Murphy's law states: "A roadside breakdown will require the only tool and/or part not in your trunk"
