LITE WEIGHT CARPET
#3155789
07/01/23 02:32 AM
07/01/23 02:32 AM
Posts: 608 TN
1DGEMAN
TN
NHRA class car what is a good source of lite weight carpet? Thanks in advance, Rod
Real Men shift for themselves
Re: LITE WEIGHT CARPET
[Re: Cab_Burge]
#3155956
07/01/23 02:37 PM
07/01/23 02:37 PM
Posts: 11,721 Portage,michigan
B3422W5
Portage,michigan
[b][/b]
Regular carpet set only weighs 25 pounds, so weight savings isn’t gonna amount to much getting something lighter that will probably look cheezy
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#3156019
07/01/23 06:31 PM
07/01/23 06:31 PM
Posts: 11,621 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
[b][/b]
Regular carpet set only weighs 25 pounds, so weight savings isn’t gonna amount to much getting something lighter that will probably look cheezy Aircraft carpet is the right answer. 25 pounds in a Stocker is a bunch. I've spent considerable time trimming that much out of a car.
[Re: CMcAllister]
#3156072
07/01/23 10:29 PM
07/01/23 10:29 PM
B3422W5
Portage,michigan
[b][/b]
Regular carpet set only weighs 25 pounds, so weight savings isn’t gonna amount to much getting something lighter that will probably look cheezy Aircraft carpet is the right answer. 25 pounds in a Stocker is a bunch. I've spent considerable time trimming that much out of a car. Those cars typically have to weigh 3300 + pounds(Abody small blocks). They sometimes carry extra weight to get there. Sure, stock carpet is 25 pounds, but whatever you replace it with doesn’t weigh zero, it weighs something. I wouldn’t think carpet is bad weight compared to other things.
[Re: B3422W5]
#3156140
07/02/23 09:35 AM
07/02/23 09:35 AM
Posts: 1,607 westerly, ri. usa
440lebaron
westerly, ri. usa
home depot. not to many colors, .60 square ft. took out power seats, a/c heater unit, wipers, carpets. spare tire etc. had to add 600 lbs. to make weight
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: actionange]
#3156815
07/04/23 09:40 AM
07/04/23 09:40 AM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
Home Depot indoor/outdoor I believe it was 6x8 roll. My wife made patterns with brown masking paper. Then transposed it to the carpet. Cut out pieces. Trim around roll bar. Affix with carper tape and Velcro as needed. Lite weigh and looks great. That looks VERY nice! Great Job! I ended up using the carpet they put on speaker boxes. Very thin, very lightweight, BUT, very easy to damage. My heel wears a hole in it at least once a season. I like your idea and will go with this stuff next time. -Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
