Switch to synthetic oil
#3155024
06/28/23 07:27 PM
06/28/23 07:27 PM
Posts: 574 Just South of The Motor City
limechallenger
I've got a 70 Challenger T/A with a slightly built 340-6 ,I've always used conventional oil,but wondering if a switch to synthetic will have any negative affects? Thought I'd ask before doing it! Thanks
70 T/A Challenger
78 Aspen R/T
87 Indy 500 Dakota
Re: Switch to synthetic oil
[Re: limechallenger]
#3155042
06/28/23 08:21 PM
06/28/23 08:21 PM
Posts: 6,245 nowhere
Sniper
nowhere
So it's a worthwhile switch for older motors? Unless you are leaking oil already it is a worthwhile switch.
#3155111
06/29/23 01:00 AM
06/29/23 01:00 AM
Posts: 10,208 Someplace you aren't
SomeCarGuy
Synthetic will clean better and gunked up or coked deposits can be cleaned away over time and you’ll have a new leak. That’s the only downside other than price.
I want my fair share
[Re: Cab_Burge]
#3155125
06/29/23 05:03 AM
06/29/23 05:03 AM
Posts: 10,714 North Dakota
6PakBee
North Dakota
Try it and tell us how well that worked out for you.
[Re: moparx]
#3155557
06/30/23 01:11 PM
06/30/23 01:11 PM
Posts: 28,596 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
keep in mind, the super thin [wt wise] oils are for modern engine clearances, which are much tighter. This. On the Engine Masters the 20/50 even made more power, over the thin stuff But in that case it showed it was the right oil for that motor.
[Re: 340SIX]
#3155617
06/30/23 04:04 PM
06/30/23 04:04 PM
Posts: 43,172 Bend,OR USA
Cab_Burge
[Re: topside]
#3155804
07/01/23 07:12 AM
07/01/23 07:12 AM
Posts: 2,917 A shed in England
Tig
A shed in England
Yeah, their conclusion was that the thicker 20W-50 aided ring seal in that engine. I was a bit surprised that it picked up power vs the thinner oil, but there it was... Whether there was an issue with that engine's ring seal wasn't analyzed. Me too, I just wondered if that engine which was quoted to have "a ton of laps on" (Dyno), would be equally as worn when compared to a used street / strip or a drag race engine that's made 100+ passes
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
