Gen 2 rocker assembly? #3154515
06/26/23 09:58 PM
06/26/23 09:58 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
Was putting on my my non stock rocker assembly onto a new set I bought and I realized. There is nothen between the
Springs on the shafts and the alum stands...
There is to be something there correct? And where can I buy them?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Gen 2 rocker assembly? [Re: toplescuda] #3154526
06/26/23 10:41 PM
06/26/23 10:41 PM
A727Tflite Offline
A727Tflite  Offline
Thin spring shim fills the void.
Re: Gen 2 rocker assembly? [Re: A727Tflite] #3154567
06/27/23 12:42 AM
06/27/23 12:42 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Mancini, 440 Source, Marsh Performance. They are used on wedges so everyone has them.
edit: They go between the rocker and the shaft.
2011 Drag Pak Challenger
Re: Gen 2 rocker assembly? [Re: rickseeman] #3154573
06/27/23 03:32 AM
06/27/23 03:32 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Being the rockers are machined flat on ends where the spring is not. I would thought they would went between the spring and stands sp the end of spring would not eat into the softer alum stands?
1971 charger
Re: Gen 2 rocker assembly? [Re: toplescuda] #3154691
06/27/23 01:46 PM
06/27/23 01:46 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I've always thought that there wouldn't be a downside to having one between the spring and the stand but that's not the way it's done.
Re: Gen 2 rocker assembly? [Re: rickseeman] #3154745
06/27/23 06:05 PM
06/27/23 06:05 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
I will have to order some
1971 charger
