Gen 2 rocker assembly?
#3154515
06/26/23 09:58 PM
06/26/23 09:58 PM
Posts: 8,857 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Was putting on my my non stock rocker assembly onto a new set I bought and I realized. There is nothen between the Springs on the shafts and the alum stands... There is to be something there correct? And where can I buy them?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: Gen 2 rocker assembly?
[Re: toplescuda]
#3154526
06/26/23 10:41 PM
06/26/23 10:41 PM
Posts: 3,101 Michigan
A727Tflite
Was putting on my my non stock rocker assembly onto a new set I bought and I realized. There is nothen between the Springs on the shafts and the alum stands... There is to be something there correct? And where can I buy them? Thin spring shim fills the void.
[Re: A727Tflite]
#3154567
06/27/23 12:42 AM
06/27/23 12:42 AM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Mancini, 440 Source, Marsh Performance. They are used on wedges so everyone has them.
edit: They go between the rocker and the shaft.
2011 Drag Pak Challenger
[Re: rickseeman]
#3154573
06/27/23 03:32 AM
06/27/23 03:32 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
Being the rockers are machined flat on ends where the spring is not. I would thought they would went between the spring and stands sp the end of spring would not eat into the softer alum stands?
[Re: toplescuda]
#3154691
06/27/23 01:46 PM
06/27/23 01:46 PM
rickseeman
Stuttgart, Arkansas
I've always thought that there wouldn't be a downside to having one between the spring and the stand but that's not the way it's done.
[Re: rickseeman]
#3154745
06/27/23 06:05 PM
06/27/23 06:05 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
I will have to order some
