Re: plugging Dipstick hole?
[Re: modelmakerinc]
#3154423
06/26/23 03:14 PM
06/26/23 03:14 PM
Posts: 4,534 Wichita
GY3
Wichita
They had a factory plug in the truck blocks.
Personally, I would tap the hole and put a bolt in it with sealant.
[Re: GY3]
#3154429
06/26/23 03:23 PM
06/26/23 03:23 PM
Posts: 2,996 Michigan
A727Tflite
I’m lazy, I always tapped a header bolt in to the hole after applying RTV.
When I say tapped, I mean with a hammer, not threaded.
Easy in, easy out.
[Re: modelmakerinc]
#3154430
06/26/23 03:27 PM
06/26/23 03:27 PM
Posts: 9,983 A Red State
SNK-EYZ
A Red State
A piece of metal rod the right diameter could just be tapped into the hole with a hammer, it's something like 5/16th or 3/8th in diameter. Measuring the diameter of the dipstick tube will let you know. A little RTV can be applied if you choose to.
That way you can knock it out later if needed, kinda like knocking out a broken off dipstick tube.
[Re: modelmakerinc]
#3154443
06/26/23 03:54 PM
06/26/23 03:54 PM
Posts: 11,113 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
1/8 NPT tap and plug. Dont think I even had to touch it with a drill.
[Re: CMcAllister]
#3154455
06/26/23 04:32 PM
06/26/23 04:32 PM
SNK-EYZ
A Red State
1/8 NPT tap and plug. Dont think I even had to touch it with a drill. The problem with tapping threads into it is that you use the factory style press in oil dipstick tube ever again you would be worrying about it leaking oil from the hole. Unless you barely tap threads into it. It sounded like he wanted the option of possibly using the hole with a factory dipstick tube again in the future. To me a piece of rod knocked into the hole would be far easier to do than dealing with tapping threads into the hole.  Using a truck pan with the rear sump means that the oil dipstick tube is mounted to the side of the oil pan rather than going into the pan rail of the block, which is why he want to plug the hole (at least for now).
[Re: SNK-EYZ]
#3154457
06/26/23 05:14 PM
06/26/23 05:14 PM
Posts: 1,578 westerly, ri. usa
440lebaron
westerly, ri. usa
1/8 npt tap fits without drilling, just tap 1/4 down , dipstick will later fit in, cleanest way i have seen, done many times
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: modelmakerinc]
#3154477
06/26/23 06:20 PM
06/26/23 06:20 PM
Posts: 30,642 Oregon
AndyF
Fellas, I'm putting a truck pan on a 440 and its dipstick goes into a fitting on the side of the pan. So what is the preferred way to plug the stock hole. i don't want to modify the hole so as to be able to reuse it if the engine finds its way into a car in the future. I repro the factory plug: https://arengineering.com/products/plug-dipstick
[Re: AndyF]
#3154608
06/27/23 07:52 AM
06/27/23 07:52 AM
Posts: 3,997 Mo.
racerx
Mo.
Fellas, I'm putting a truck pan on a 440 and its dipstick goes into a fitting on the side of the pan. So what is the preferred way to plug the stock hole. i don't want to modify the hole so as to be able to reuse it if the engine finds its way into a car in the future. I repro the factory plug: https://arengineering.com/products/plug-dipstick Andy does that plug require you to use a Tap? In one of the pictures it looking like it.
[Re: racerx]
#3154619
06/27/23 08:23 AM
06/27/23 08:23 AM
Posts: 11,650 W. Kentucky
justinp61
W. Kentucky
Fellas, I'm putting a truck pan on a 440 and its dipstick goes into a fitting on the side of the pan. So what is the preferred way to plug the stock hole. i don't want to modify the hole so as to be able to reuse it if the engine finds its way into a car in the future. I repro the factory plug: https://arengineering.com/products/plug-dipstick Andy does that plug require you to use a Tap? In one of the pictures it looking like it. Looking at the last photo in the link, no.
[Re: racerx]
#3154641
06/27/23 09:51 AM
06/27/23 09:51 AM
AndyF
Fellas, I'm putting a truck pan on a 440 and its dipstick goes into a fitting on the side of the pan. So what is the preferred way to plug the stock hole. i don't want to modify the hole so as to be able to reuse it if the engine finds its way into a car in the future. I repro the factory plug: https://arengineering.com/products/plug-dipstick Andy does that plug require you to use a Tap? In one of the pictures it looking like it. No tap required. It is a slight press fit, just like the factory plug
[Re: A727Tflite]
#3154880
06/28/23 07:41 AM
06/28/23 07:41 AM
Posts: 13,226 Marion, South Carolina [><]
an8sec70cuda
Easy in, easy out.  Same here.
[Re: AndyF]
#3154888
06/28/23 07:58 AM
06/28/23 07:58 AM
GY3
Wichita
Pretty big mark up on those! Looks similar to Mopar Performance / Direct Connection pricing!
[Re: GY3]
#3154890
06/28/23 07:59 AM
06/28/23 07:59 AM
an8sec70cuda
Pretty big mark up on those! Looks similar to Mopar Performance / Direct Connection pricing! And Rick E-berg's on ebay, lol.
