Fuel Pressure Regulator
#3154388
06/26/23 02:22 PM
06/26/23 02:22 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
I came to the racing forum as this is a piece I am looking to lower pressure on my Cummins. I have swapped the original a 98.5 Carter fuel assembly/pump that puts me close to blowing out the shaft seal on the Bosch VE injector pump. Is there such an animal? The pump puts out 18lbs if the gauge is right. Trimming it down to 15 is the goal. If you blow the front deal it floods the crankcase with fuel. haven't been around here much.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Fuel Pressure Regulator
[Re: Rug_Trucker]
#3154877
06/28/23 08:38 AM
06/28/23 08:38 AM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
I would think any deadhead style regulator that operates in that pressure range would work. I don't think it needs to be a diesel specific regulator since I know a bunch of people running normal gas pumps as lift pumps on their Cummins trucks...like a Holley blue pump for example. Just a quick search on Summit's website showed only a couple of options in the 10-25 psi range and they were all around $200. There's got to be something cheaper for this application though.
[Re: an8sec70cuda]
#3154894
06/28/23 09:20 AM
06/28/23 09:20 AM
Rug_Trucker
No doubt. I see "gasoline" on some things. I am guessing that's for the E85 folks. The Issipro boost and pyro gauges were crazy expensive.
[Re: Rug_Trucker]
#3154901
06/28/23 09:48 AM
06/28/23 09:48 AM
an8sec70cuda
Yes, I had an ISSPro fuel pressure gauge on my '01 Cummins that worked great, but was expensive. I put a cheap set of GlowShift gauges (boost, EGT, & trans. temp) w/ the pillar mount bezels on it that worked really well. Had them for about 7 years w/ no trouble at all.
[Re: Rug_Trucker]
#3154963
06/28/23 02:15 PM
06/28/23 02:15 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
