Repop 15 x 7 Rallys #3151055
06/13/23 01:26 AM
06/13/23 01:26 AM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
Hi
Is anyone running US Wheel repops? Have you had any issues?
I'm in need of a couple of 15 x 7 Rallys for my new project.
People were asking breathtaking prices for factory originals at the last swap, I think aftermarket is the way to go.
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: Repop 15 x 7 Rallys [Re: Hrtbkr] #3151282
06/13/23 05:54 PM
06/13/23 05:54 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
That right there should tell you why good OEM ones are going for so much. It'll be interesting to hear some replies here with stories of the reproductions.
Re: Repop 15 x 7 Rallys [Re: Hrtbkr] #3151345
06/13/23 08:22 PM
06/13/23 08:22 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I think mine might be US Wheel, I hate them, they don't sit flush with the hub, so I have to pull it down with the lug nut. I think maybe all of the china wheel have some sort of issue.
Re: Repop 15 x 7 Rallys [Re: 71birdJ68] #3151368
06/13/23 09:38 PM
06/13/23 09:38 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Back when we had a Mopar club several guys had Wheel Vintiques wheels on their cars. You could tell what they were by the battleship solid gray color they come in as it's not quite right. I think those are ok quality?
Before you mount a tire to a repo steel wheel you want to have them spun on the balancer to make sure they are within spec. Many places won't take them back if you put the tires on first.
Might also want to see how the trim rings fit also. Some aftermarket wheel and trim ring combos leave a gap at the wheel face.
Re: Repop 15 x 7 Rallys [Re: Neil] #3151377
06/13/23 10:32 PM
06/13/23 10:32 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Yes on the Wheel Vintiques back in the day - Having to scuff perfectly good powder coating so you could spray the proper Silver Argent
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Repop 15 x 7 Rallys [Re: bee1971] #3151427
06/14/23 10:18 AM
06/14/23 10:18 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Mine are well over 25 years old sprayed in the proper silver and over 55,0000 miles with no issues ever.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Repop 15 x 7 Rallys [Re: 6PKRTSE] #3151438
06/14/23 10:53 AM
06/14/23 10:53 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Since the late '80s, I've bought maybe a dozen sets of repro Mopar wheels - Rallyes & Magnums - for my A & B bodies.
Never had a runout, straightness, or balance issue until a few years ago, which happened to be some Magnums from Coker after they bought Wheel Vintiques & Specialty.
One of the 4 was visibly wobbly, and after proving so with a readout from my tire shop, they replaced it.
I always thought there's be a fixture so the spider is "square" with the barrel when welded, but apparently not, or it wasn't checked.
I asked them about QC and the guy at Coker said they don't check dimensional quality.
Last set I bought came from Holley via Ebay - straight, radial runout was about .060 on a couple, but they balanced and have driven fine.
Bottom line: check them before mounting tires.
Re: Repop 15 x 7 Rallys [Re: 71birdJ68] #3151497
06/14/23 02:11 PM
06/14/23 02:11 PM
moparx Offline
moparx  Offline
unfortunately, cranking them flush to the mounting surface can cause some "fun" when removing them if the center bore diameter is too small, causing a light press fit.
i have seen this happen on factory wheels that had too much powder coat applied. after lots of "words not to be said around women and children" being used, beating on the back side of the wheel/tire with a sledge, then finally loosening the lugnuts a couple turns and slowly driving in a circle while slamming on the brakes several times, the wheel finally popped loose from the hub.
if the center bore of the wheel does not allow it to fit flush to the hub mounting surface, it has to be opened up the smallest amount necessary for it to do so. if that means the removal of powder coat, chrome, or just wheel material, so be it.
just my opinion. your mileage will vary.
beer
Re: Repop 15 x 7 Rallys [Re: bee1971] #3151713
06/15/23 08:29 AM
06/15/23 08:29 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I kinda have a small wheel collection here.
Quite a,few sets of 15x7 and 15x8.Wheel Vintques here. A,quick scuff prime and paint was all they needed. Checked runout and balanced all were good to go. Were good as factory 15x6.5 and 15x7 rallies to me.
Only downside on 15x8 was trim rings gap, but need 8 inch wide for large Drag Radials
Also have factory 15x6.5, 15x7 and a pair of 15x8 Ram Charger Wheels tanks You-Pull-It.
I did not want to trust new China wheels.
Like posted above the new Repops are hit and miss
My wife lets me sell nothing. Says we may need them one day.
I would get older Wheel Vintques or factory and pay the extra
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Repop 15 x 7 Rallys [Re: 340SIX] #3151798
06/15/23 02:44 PM
06/15/23 02:44 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Wheel Vintiques on my Charger years ago and they were fine. I can`t say for the new stuff out there.
Re: Repop 15 x 7 Rallys [Re: mopars4ever] #3153714
06/23/23 01:02 AM
06/23/23 01:02 AM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
I ended up buying a couple of Wheel Vintiques.
I had them spun and they were no better (or worse) than the OEM pair I'm also using.
I'm goin to have to paint them to match the other wheels, so the finish doesn't matter.
Thanks for all the advice
Re: Repop 15 x 7 Rallys [Re: Hrtbkr] #3153866
06/23/23 03:55 PM
06/23/23 03:55 PM
moparx Offline
moparx  Offline
i'm curious if anyone has spun original wheels, then the reproductions, and checked how balanced they are ?
beer
Re: Repop 15 x 7 Rallys [Re: moparx] #3153889
06/23/23 06:19 PM
06/23/23 06:19 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
beer
I spun the repops and pair of original wheels for the original poster and the wheels had the same amount of runout. About.030-.050 (thousandths) on both the repops and original wheels.
Re: Repop 15 x 7 Rallys [Re: SNK-EYZ] #3154093
06/24/23 10:19 PM
06/24/23 10:19 PM
NW New Jersey
RSI700VIPER Offline
RSI700VIPER  Offline
NW New Jersey
Bought a set of US wheels 15x7s about 2 years ago. They looked great but the welds on the back were terrible. About 30-40 percent missed the intended location joining the hub to the rim. I sent them back and bought a set of originals.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
