Swapping Front Bearing Retainer - Large to Small
#3152767
06/19/23 05:52 PM
06/19/23 05:52 PM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
So finding out I have a 68 833 4-speed and a 67 Bell housing. Long story short, I want to use this transmission and bell housing, but as you know the transmission has the larger front bearing retainer and the bell housing takes the smaller front bearing retainer. Can I buy a smaller front bearing retainer and swap it onto my 68 833? Thanks for help.
RS23L7 4-Speed
Re: Swapping Front Bearing Retainer - Large to Small
[Re: Mopar_Mike]
#3152770
06/19/23 06:04 PM
06/19/23 06:04 PM
Posts: 6,291 nowhere
Sniper
nowhere
So finding out I have a 68 833 4-speed and a 67 Bell housing. Long story short, I want to use this transmission and bell housing, but as you know the transmission has the larger front bearing retainer and the bell housing takes the smaller front bearing retainer. Can I buy a smaller front bearing retainer and swap it onto my 68 833? Thanks for help. There area, at least, three front bearing retainer sizes and two bolt patterns. The smallest retainer will not bolt up to the largest bolt pattern, IIRC. So we need to know exactly what you have. http://www.brewersperformance.com/products.php?cat=82
[Re: Sniper]
#3152773
06/19/23 06:25 PM
06/19/23 06:25 PM
Mopar_Mike
Danville, NH
C97621 is on the 68 transmission. It is an 18 spline overdrive 4-speed built by Jamie Passon 10 or so years ago. I want to use it in my 67 440 GTX but I would like to keep the factory cast iron bell housing.
RS23L7 4-Speed
[Re: Mopar_Mike]
#3152907
06/20/23 03:06 AM
06/20/23 03:06 AM
Posts: 43,237 Bend,OR USA
Cab_Burge
[Re: fastmark]
#3152923
06/20/23 07:04 AM
06/20/23 07:04 AM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Guys? He said; as you know the transmission has the larger front bearing retainer and the bell housing takes the smaller front bearing retainer There is not an adapter to go from large bearing retainer to small.
[Re: moparx]
#3153066
06/20/23 02:44 PM
06/20/23 02:44 PM
Mopar_Mike
Danville, NH
Just emailed Brewers about any possible solutions.. but, if I decided to go with the making the bell housing hole bigger, what would be involved. Could any engine builder/machine shop do it? Is it costly? would I ever be able to use the original smaller retainer transmission again?
RS23L7 4-Speed
[Re: Mopar_Mike]
#3153118
06/20/23 06:24 PM
06/20/23 06:24 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
Just emailed Brewers about any possible solutions.. but, if I decided to go with the making the bell housing hole bigger, what would be involved. Could any engine builder/machine shop do it? Is it costly? would I ever be able to use the original smaller retainer transmission again? Making the bellhousing hole bigger would require I believe also relocating the the clutch fork pivot over as it is very close the the hole, this may also require a different fork to go with that? I would have a machine shop do it , costly , probably but you got it ... . You would be able to use your other transmission with just a bearing retainer swap or an adapter ring to fill the hole back in. The big block A body uses the same bell, I want run a hemi 4 speed in my dart but didn't want to modify my original bellhousing so after doing some comparing it looks like the 70/up 130 tooth BB alum bellhousing is a copy of the 67 cast iron with a larger bearing retainer hole. The other thing you could do is put the guts of your trans into a small bearing case, it's not very hard to do, though the OD trans went to the 308 front bearing for a reason?
[Re: Sniper]
#3153186
06/20/23 09:27 PM
06/20/23 09:27 PM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
if I decided to go with the making the bell housing hole bigger, what would be involved. You DO NOT want to do that.
[Re: Stanton]
#3153254
06/21/23 08:09 AM
06/21/23 08:09 AM
Posts: 1,330 VA
dragon slayer
VA
You have a 68 HEMI transmission. The C97621 is the large diameter 4.805"dia, 308 bearing with 4.16" hole pattern. The bearing and hole pattern are on your transmission so you can't change that without swapping case. Your trying to stick this in a Bell House that need a 4.354 diameter retainer.
So messing with a BH is problematic. Your alternative is to get the over drive retainer that has 5.125 dia, 308 bearing and 4.16 hole pattern. Turn it down to 4.354. This would also be pretty close to cutting into the holes of the retainer. This is much easier to do. BUT since your a 18sp, they will also have to put a sleeve on the tube the throwout bearing rides on and bore the diameter out. Lot of work, but I think better then working on BH. Frankly I would look for the 68 BH.
I have turned a OD retainer for a 308 23 spline to the large hole 4.805. That was easy and worked. You really may be stuck with changing Case or BH.
[Re: dragon slayer]
#3153271
06/21/23 08:50 AM
06/21/23 08:50 AM
Mopar_Mike
Danville, NH
I have turned a OD retainer for a 308 23 spline to the large hole 4.805. That was easy and worked. You really may be stuck with changing Case or BH. Seems like a lot of work and cost to try to modify what I have to work the way I want it to. Brewers also mentioned just switch the bell housing. Since it is the wrong (numbers wise) transmission anyways. Thanks again for everyone's help.
RS23L7 4-Speed
[Re: Mopar_Mike]
#3153447
06/21/23 10:06 PM
06/21/23 10:06 PM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Is there enough meat on an 18 spline retainer to turn it down to the size your bellhousing is? As you said, your trans isn't the "correct" one anyway so if you can source a compatible bellhousing, that's probably the easy button solution provided it's compatible with your clutch and flywheel. Most of the car show "experts" will be too busy yammering on about their uncle's factory 383 hemi 62 Valiant to notice anyway. Kevin
