Arc over ribs in distributor cap #3152754
06/19/23 04:44 PM
06/19/23 04:44 PM
Seattle, WA
3
375inStroke Offline OP
Special needs person
3
Seattle, WA
It looks like the new Mopar tan caps, at $25, don't have the anti-crossfire ribs in them. What are your thoughts on this?
Re: Arc over ribs in distributor cap [Re: 375inStroke] #3152913
06/20/23 03:41 AM
06/20/23 03:41 AM
iI've used them in my old E85 bracket motor with 15.0 to 1 compression ratio with a MSD 7AL2 no issues up to 7300 RPM shruggy
Same thing on the new black caps like them. I do prefer the older ones with those ribs in them but I haven't been able to find a reliable source for them in the last five years whiney shruggy
Re: Arc over ribs in distributor cap [Re: Cab_Burge] #3152986
06/20/23 11:07 AM
06/20/23 11:07 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
It's probably 5 cents cheaper to make them without the ribs.
Re: Arc over ribs in distributor cap [Re: 375inStroke] #3152989
06/20/23 11:17 AM
06/20/23 11:17 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I'm shocked Mopar sells anything for a pre-2003 vehicle.
Rich H.
Esse Quam Videri
Re: Arc over ribs in distributor cap [Re: Cab_Burge] #3153033
06/20/23 12:31 PM
06/20/23 12:31 PM
Seattle, WA
3
3
Seattle, WA
Only ones with them I've been able to find are Echlin in black, but if a plain cap works for you, I guess I won't worry about it.
Re: Arc over ribs in distributor cap [Re: 375inStroke] #3153043
06/20/23 01:05 PM
06/20/23 01:05 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
The last few Accel 120323's I bought were tan, and they had the ribs on the inside. They were made in Chy-na though.
