Re: Weld motor mounts onto a block ?
[Re: hemienvy]
#3152872
06/19/23 10:35 PM
06/19/23 10:35 PM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
I'm having a hard time imagining how this would ever be easier/better than repairing the original mount bosses.
[Re: INTMD8]
#3152882
06/19/23 11:12 PM
06/19/23 11:12 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I would be worried about different expansion rates of steel alloy and the cast iron block. I would also seek to repair the orig mounting tabs. Just me though.
[Re: dustaboy74]
#3152966
06/20/23 10:12 AM
06/20/23 10:12 AM
Posts: 4,669 Wichita
GY3
Wichita
People with higher HP engines have stated that mounts on the side of the block can distort the cylinder bore under load.
Whether this is true or not, I have no idea.
[Re: SNK-EYZ]
#3152981
06/20/23 10:53 AM
06/20/23 10:53 AM
Posts: 4,712 Moved to N.E. Tennessee
GomangoCuda
Pics of the bad/damaged, motor mount pads might help with opinions on how to fix it. ^ this
[Re: hemienvy]
#3152983
06/20/23 10:59 AM
06/20/23 10:59 AM
GomangoCuda
If you had a valuable block with screwed up, or bad/damaged, motor mount pads, I know you can rig up a front motor mount plate.
What about welding a flat plate, say 4" x 4", on each side of the block, IN ANY NEW SPOT YOU DESIRE, to use "conventional-style" mounts (Mopar, Chevy, Ford). Actually I am thinking that if you do this to a "valuable" block then you will no longer have a "valuable" block.
[Re: GomangoCuda]
#3152993
06/20/23 11:27 AM
06/20/23 11:27 AM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
I'd go with tried and true and would either repair the existing mounts, or would use a motor plate.
Yep, done to death, super boring, and not thinking out of the box.
Not to say the proposed solution wouldn't be functional, but Sometimes over-utilization of creativity and imagination can bite you later on, like if you ever need to sell any of it....
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3152996
06/20/23 11:37 AM
06/20/23 11:37 AM
Posts: 11,531 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Getting away from the stock mounts and welding a plate on the side of the block sounds like a recipe for disaster.
The OE blocks are not thick. Dissimilar metals. Cracks. Failure of the block is how I see this ending up.
[Re: CMcAllister]
#3153029
06/20/23 12:24 PM
06/20/23 12:24 PM
Posts: 906 Washington
hemienvy
Washington
OK thanks gents, good points.
In this case I'm not referring to any specific block, just a general case, so no pics.
I will add this, to the point of changing the mount location on the block adding stress, that is exactly what is happening when using a front motor plate.
As far as welding a steel plate to cast iron, I thought you could safely do that, maybe not.
Personally speaking, the resale aspect doesn't concern me, but that is a good point.
What if you wanted to put a Hemi in an old truck, would you use stock Hemi mounts in the stock location ?
I think the outside wall of pretty much any block is not attached internally to anything, just top & bottom, front & back.
[Re: hemienvy]
#3153070
06/20/23 02:51 PM
06/20/23 02:51 PM
Posts: 19,363 north of coder
moparx
"What if you wanted to put a Hemi in an old truck, would you use stock Hemi mounts in the stock location ?" use the stock engine mounts, and fabricate what is needed to the chassis of choice. not a particularly hard task. cardboard, chip board, etc. is your friend here. position the engine in the desired position, then cut out the cardboard to the desired pattern for the mounts, transfer the pattern to steel. weld away, done. as to welding a plate to the engine block, no...........
[Re: jwb123]
#3153101
06/20/23 05:15 PM
06/20/23 05:15 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
Id use an engine place and a midplate. I've been doing that way for years and NEVER an issues with an stress or wear from the plate. I have done this from 800hp to 1200 and change with Mopar stuff and not an issue
[Re: hemienvy]
#3153212
06/20/23 11:13 PM
06/20/23 11:13 PM
INTMD8
Lake Villa Il
There are many things that -can- be done.
Would be amazed if relocating mounts and welding 4x4 plates onto the side of a block resulted in any better result than fixing the original mount locations at less than 10 times the time/effort.
[Re: hemienvy]
#3153253
06/21/23 07:57 AM
06/21/23 07:57 AM
Posts: 4,206 New York
polyspheric
New York
A thermal mass analogy:
Compare this to welding a gum wrapper to the Titanic hull. How to get (and keep) them at the same temperature? How to pre-heat a block?
Don't do it.
Boffin Emeritus
