p5007628 block+ #3152134
06/16/23 08:23 PM
06/16/23 08:23 PM
Houston, Texas
sean1970 Offline OP
sean1970  Offline OP
Houston, Texas
Question on this style of block? Can it be bored 4.500? p5007628 Appreciate any help. TY
Re: p5007628 block+ [Re: sean1970] #3152210
06/17/23 02:50 AM
06/17/23 02:50 AM
You should have it sonic tested first before deciding. If it has less than .160 on the thrust sides at 4.500 don't do it tsk
Maybe shoot for 4.400 or so twocents scope
Re: p5007628 block+ [Re: Cab_Burge] #3152245
06/17/23 09:49 AM
06/17/23 09:49 AM
Houston, Texas
sean1970 Offline OP
sean1970  Offline OP
Houston, Texas
Cab,
Thank you sir. I was just curious not familiar with that block. Hope your great! Sean
Re: p5007628 block+ [Re: sean1970] #3152274
06/17/23 12:26 PM
06/17/23 12:26 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
P5007628 is a 500” crate engine.
Re: p5007628 block+ [Re: fast68plymouth] #3152301
06/17/23 01:38 PM
06/17/23 01:38 PM
Houston, Texas
sean1970 Offline OP
sean1970  Offline OP
Houston, Texas
Guy ended up being a scammer. Google is your friend.
Re: p5007628 block+ [Re: sean1970] #3152355
06/17/23 04:53 PM
06/17/23 04:53 PM
birdtracker Offline
birdtracker  Offline
what was the sign on name that he messaged you with? Birdtracker
Re: p5007628 block+ [Re: birdtracker] #3152360
06/17/23 05:40 PM
06/17/23 05:40 PM
tboomer Offline
tboomer  Offline
Yes...I would like to know.. work
Re: p5007628 block+ [Re: tboomer] #3152371
06/17/23 07:09 PM
06/17/23 07:09 PM
Houston, Texas
sean1970 Offline OP
sean1970  Offline OP
Houston, Texas
On Facebook. I can post there names if you like. One of the pics was from here in 2014 believe it or not.
Re: p5007628 block+ [Re: sean1970] #3152438
06/18/23 06:17 AM
06/18/23 06:17 AM
tboomer Offline
tboomer  Offline
Yeah..We can't do anything on Moparts if it is a facebook ad. But uou should out the rat here so our members here don't get scammed by the thief! wave
Re: p5007628 block+ [Re: tboomer] #3152477
06/18/23 10:54 AM
06/18/23 10:54 AM
Houston, Texas
sean1970 Offline OP
sean1970  Offline OP
Houston, Texas
Jessica Harris Gabe Tanny
