Re: 528-541 stock block
[Re: sean1970]
#3151883
06/15/23 08:44 PM
06/15/23 08:44 PM
Posts: 31,091 Oregon
AndyF
Has anyone built a 541 with the stock block or 528? Is the block just to weak to handle big hp 900-950? I'd limit a stock 440 block to a 505 with a 4.25 crank and roughly 750 or maybe 800 hp. Anything more than that then step up to an aftermarket block.
[Re: sean1970]
#3151889
06/15/23 08:59 PM
06/15/23 08:59 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Damn block are so much money now its crazy unless I could find an mopar block M If you can afford to make 900-950 horsepower the cost of a good block should be peanuts to you.
[Re: sean1970]
#3151927
06/16/23 12:58 AM
06/16/23 12:58 AM
AndyF
Damn block are so much money now its crazy unless I could find an mopar block M Yep, that is correct. I'm building a Ford 521 right now. It will make 850 hp using a stock late model Ford truck block and Kaase SR-71 heads. I'm not sure I'll ever build another Mopar big block for myself. Just too expensive.
[Re: quickd100]
#3151948
06/16/23 07:39 AM
06/16/23 07:39 AM
Posts: 12,419 Taxes & Virus's R-US, NY
Dragula
So I have built a bunch of +500 Mopar strokers in the last few years. And our current package comes in right around 800hp....Now I have not pushed one much past that with a stroker kit....We have had zero issues at that level. We run good parts, and a girdle on everyone. I do not like a partially filled block, it heats up super quick, and can be a pain to cool.
The key for us, we keep the rpm down under 7k...Typically 6500...For all the big strokers.
I also have one engine its only a +.030 440, but its blown, and it has been pushed to 1200hp on 20lbs of boost...It is partially filled and requires an engine oil cooler to keep cool and has the biggest girdle I have ever seen and aluminum caps all locked in......One of those kits with caps and girdle.
Now at 900hp, I would say, your flirting with disaster in a stock block. Its not going to hold up to weekly thrashings like an aftermarket block...If its an occasional trip down the track and turbo charged where it does not see the track weekly, it might hold up for a while.
[Re: sean1970]
#3151965
06/16/23 08:39 AM
06/16/23 08:39 AM
Posts: 4,101 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Has anyone built a 541 with the stock block or 528? Is the block just to weak to handle big hp 900-950? Because HP numbers are thrown around here liberally, you'd be better to ask the question differently. lf you stated your targets like; "mid-high 8's in a 3300lb dedicated drag car (with driver) ON MOTOR" you'd get better answers. I may have misunderstood your post but if someone lead you to believe they could do such a motor for 12000 from scratch that'd live, you were misled. Use the google search on here, there are plenty of good posts about how we've gone about it. And use Wallace Racing Automotive calcs to get an idea of what you need for HP to reach your target.
[Re: B1MAXX]
#3151967
06/16/23 08:41 AM
06/16/23 08:41 AM
HardcoreB
Shelby Twp. Mi
How fast are you looking to go? Is a better question. Just giving you credit for saying it first.
[Re: HardcoreB]
#3151981
06/16/23 09:15 AM
06/16/23 09:15 AM
Posts: 2,527 PA
moparacer
PA
My tall filled 400 block makes 850 on a good day but its only a 4.15 stroke. And the 400 are better in the main web at handling that.
I definitely wouldn't push a 440 block past that.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: sean1970]
#3151987
06/16/23 09:41 AM
06/16/23 09:41 AM
Posts: 4,706 Wichita
GY3
Wichita
Has anyone built a 541 with the stock block or 528? Is the block just to weak to handle big hp 900-950? You'll get 10 people that say it won't to every 1 person that says it will. We have no issues with a stock RB block a that has been main studded and using a 4.25 stroke crank. Horsepower varies depending on what nitrous jet is in it that weekend.
