Re: 1" pullout for driveshaft measurement?
[Re: BDW]
#3151251
06/13/23 03:50 PM
06/13/23 03:50 PM
Posts: 88 IL
83hurstguy
IL
When I ordered my new driveshaft from Mark Williams, they will go down to 3/4" slip yoke travel (and their tech support recommended that). I think I ended up on the short side of the 3/4" due to rounding measurements.
I converted from a driveshaft with around 1-5/8" slip yoke travel and noticed a vibration improvement from the 1-5/8" to the 3/4". Leaving the U-joint hanging out there too far can be felt, at least with a four speed it can be felt in the shifter. The MW tech confirmed it's a common issue, too. People get worried about the output shaft seal dust boot, make the driveshaft too short, then have a vibration issue.
[Re: BDW]
#3151406
06/14/23 07:45 AM
06/14/23 07:45 AM
Posts: 744 Almost Heaven
Bob Stinson
Almost Heaven
You don't mention your setup but if the factory built the same body style with the same transmission and rear end, the easy way to get it right is to use the length from the FSM.
69 road runner A12 ex-racer 71 Duster w/ a 400
Shiny paint causes stress.
[Re: BDW]
#3151739
06/15/23 11:59 AM
06/15/23 11:59 AM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
So is it better err on a longer DS, 1/2" pulllout? Keep in mind that the u-joint cups are are 1"+ in diameter and the cradle in the rear yoke that they sit in is a little over half that deep, so you need at least that much in order to push the shaft forward during installation before pulling it back into the yoke. 3/4" should cover all bases.
[Re: BDW]
#3151831
06/15/23 04:51 PM
06/15/23 04:51 PM
Posts: 4,722 Moved to N.E. Tennessee
GomangoCuda
The two different size or different brands of front yokes might be different lengths. Best to get the yoke and then measure for drive shaft. No guessing here.
[Re: GomangoCuda]
#3152002
06/16/23 11:03 AM
06/16/23 11:03 AM
Posts: 11,573 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
3/4" here.
Some kind of weird pinion angle, leaf spring setup may need more.
[Re: BDW]
#3152005
06/16/23 11:10 AM
06/16/23 11:10 AM
Posts: 4,727 Florida
BDW
Appreciate the input, another question
Would changing the front yoke to 1350 from 7290 and using a conversion u-joint change the DS length? 1350 is a little larger, so maybe only 1/16 or 1/8" ?
Thx I’ll answer my own question on this part, 1350 has 1/16” larger cup size compared to 7290. So 1/2 of that 1/16” would make it 0.030” longer, nothing to worry about. I’m going 3/4” when I get around to getting this done.
[Re: BDW]
#3152026
06/16/23 12:23 PM
06/16/23 12:23 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Thx I’ll answer my own question on this part, 1350 has 1/16” larger cup size compared to 7290. So 1/2 of that 1/16” would make it 0.030” longer, nothing to worry about. I’m going 3/4” when I get around to getting this done. True. But the hole is bigger. The C/L doesn't move. Does a larger or smaller crank pin journal change the stroke?
[Re: CMcAllister]
#3152064
06/16/23 02:29 PM
06/16/23 02:29 PM
GomangoCuda
Yes but is the bottomed out length the same on all yokes? Different brands, different materials, oem, aftermarket forged or billet. All the same?
[Re: GomangoCuda]
#3152102
06/16/23 06:07 PM
06/16/23 06:07 PM
BDW
Yes but is the bottomed out length the same on all yokes? Different brands, different materials, oem, aftermarket forged or billet. All the same? Very good question, I have 2 different yokes, 1 aftermarket cast, and a factory forged that came with the 518 when I pulled it at JY.
