Re: 727 puking fluid during a run [Re: an8sec70cuda] #3151339
06/13/23 08:13 PM
06/13/23 08:13 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I thought all the cool kids ran one? This is the race section right?? Actually I think “da rules” says we have to, either way I’ve experienced weepage at the vent with our 727 and 904. Tranz-act, Griner, Pro Trans…… all my brakes have done it in some manner. It does seem like ever since we went to the W8 mill the prob increased. I run a 47RE pan (727) or the 42RE pan on the 904 with the fluid just on the tip of the dipstick hot in N. My next race will be with the “new” 904 and that’ll have an A&A brake.
Re: 727 puking fluid during a run [Re: an8sec70cuda] #3151348
06/13/23 08:37 PM
06/13/23 08:37 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Originally Posted by an8sec70cuda
So I noticed my 727 is puking a little fluid out of the vent during a run. It does have a transbrake (Turbo Action pro brake) and the vent is relocated to the top rear of the case at about the 11:00 position when looking at it from the rear.
Why is it doing this? Is it overfull?
Should I install a breather tank? Just remove the vent and put a different fitting in the case plumbed to a catch can? Should I do it in -4an or -6an line?
Any particular catch can yall would recommend?
I found this one earlier...
https://allstarperformance.com/mini-breather-tank-panel-mount-all36142/
Any other suggestions?
Thanks beer
Next time it’s apart, use a A518 overdrive retainer gasket cut down, and punched for the holes, between the output shaft support and the case. Hot cross leak from the return flow, charging the vent cavity. You’re welcome.
Re: 727 puking fluid during a run [Re: FastmOp] #3151380
06/13/23 11:07 PM
06/13/23 11:07 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Last year mine started showing temp when making runs with-in 30 minutes. Spit the sealed dip stick out. Shortly there after the converter imploded. Swapped the converter no issues since.
doug
Re: 727 puking fluid during a run [Re: an8sec70cuda] #3151731
06/15/23 11:03 AM
06/15/23 11:03 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I put my vent in the tail shaft housing and have never seen a drop out of it. I did make a little shield to go inside over the hole so the park gear can't sling oil on it.
Re: 727 puking fluid during a run [Re: justinp61] #3151738
06/15/23 11:39 AM
06/15/23 11:39 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That is a good point, maybe Chip's vents a little bit when he stands that big hemi powered beast up on the bumper for several hundred feet!
68 Barracuda Formula S 340
Re: 727 puking fluid during a run [Re: Bad340fish] #3153486
06/22/23 05:56 AM
06/22/23 05:56 AM
MASSACHUSETTS
Chip Offline
Chip  Offline
MASSACHUSETTS
8sec...how did you make out with the trany leaking?
My trany still has the vent in the front of the pump so I too have some fluid dripping out the bellhousing now and then. Trying to figure out why too.
Re: 727 puking fluid during a run [Re: Chip] #3153502
06/22/23 08:14 AM
06/22/23 08:14 AM
an8sec70cuda Offline OP
I haven't had the car back out since. Probably won't run it again until some time in the fall. I have a few things to change before I run it again anyway. up
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 727 puking fluid during a run [Re: rickraw] #3153596
06/22/23 03:44 PM
06/22/23 03:44 PM
NC
440Jim Offline
440Jim  Offline
NC
Originally Posted by rickraw
I would check dipstick calibration. I cut out a section of the webbing under the rear support so oil can’t fill up in that area, also I plugged the oil feed hole in the end of the park paw. Stopped the small amount oil out my vent.
Chip, if it wasn't doing it before, the new vent location may be just fine.
FWIW, I ran the rear vent relocation also, and had no fluid coming out the vent. I did grind a little extra drainage in two locations on the rib below the new vent. But that rib should not seal to the gasket or the rear support (as cast), but I did add drainage so no fluid could accumulate in that cavity.
In my old race car, I found the 727 could be sensitive to a fluid level too low. Possibly due to fluid aeration if the bottom of the valve body is not covered. So go gently trying to reduce fluid level. If ET/mph drops, the trans could be aerating the fluid. It seemed strange at first, since the deep pan and filter extension will pull fluid from very low, no matter what the level.
Re: 727 puking fluid during a run [Re: 440Jim] #3153617
06/22/23 05:27 PM
06/22/23 05:27 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
That’s what I did on my case which looks like the one John Kunkel posted on the tail shaft removal post.I removed the webbing on the left side of that casting hump. No leaky.
