Wheel cylinder bore size
#3151021
06/12/23 09:40 PM
06/12/23 09:40 PM
Posts: 1,487 STL
cdstl
STL
I have a 1965 Coronet that I'm putting 2.5"x11" rear drums on. It's a manual brake car and this hasn't come up before. What size bore for the wheel cylinder should I use. They offer a 15/16" and a 1/125" bore for the wheel cylinder. I know with the master I'd use a 15/16" bore but now I'm confused a bit on which bore to get for the rear wheel cylinders. I'm going with discs up front.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Wheel cylinder bore size
[Re: TJP]
#3151053
06/13/23 12:51 AM
06/13/23 12:51 AM
Posts: 1,487 STL
cdstl
STL
The larger bore heel cylinder will apply more pressure to to the shoes but will require more fluid than the smaller bore. The inverse applies to masters IE: a smaller bore master will deliver more pressure with the same force applied, but deliver less fluid requiring a bit more pedal travel Thanks, I've just never been given an option on wheel cylinder bore sizes and wasn't sure if it was supposed to be a power vs manual brake thing.
[Re: cdstl]
#3152781
06/19/23 06:54 PM
06/19/23 06:54 PM
Posts: 1,487 STL
cdstl
STL
I got 15/16" bore AC Delco, picture showed Made in USA.
Box says Made in China.
[Re: Cab_Burge]
#3152809
06/19/23 08:08 PM
06/19/23 08:08 PM
Posts: 5,818 ohio
ruderunner
ohio
Because there's other factors involved. If the pedal stroke was held constant, you'd be correct. If stroke isn't held constant then the larger cylinder will apply more force on the shoes.
Angry white pureblood male
[Re: Cab_Burge]
#3152866
06/19/23 10:23 PM
06/19/23 10:23 PM
Posts: 15,358 Omaha Ne
TJP
Omaha Ne
in the world of Fluid the following applies, lets just put some numbers out: The formula for pressure is force divided by the surface area. If the master cylinder has a 1-inch bore, the piston’s surface area is .78 square inches. If you apply 420 lbs. (70 lbs x 6:1 pedal You divide the output force of 420 lbs. by the surface area of the piston, you would get 538 psi(420 lbs. divided by .78 inches) at the ports of the master cylinder. If you reduce the surface area of the piston you, will get more pressure. This is because the surface area is smaller, but the output force from the pedal stays the same. So, If you used a master cylinder with a bore of .75 inches that has a piston that has .44 inches of piston surface area, you would get 955 psi at the ports for the master cylinder (420 lbs. divided by .44 inches). the pressure produced by the master is multiplied by the surface area of the piston at the shoes or caliper. So a smaller piston will aplly less pressure while a larger one will apply more. One possibility is that the added pressure from the larger bore W/C was causing the backing plate or drum to flex resulting in a loss of surface area contact. Research what i have said via google and you'll find I'm not blowing smoke
[Re: Cab_Burge]
#3152919
06/20/23 06:01 AM
06/20/23 06:01 AM
Posts: 5,818 ohio
ruderunner
ohio
I have.
On my trucks I upsize the wheel cylinders for more rear braking. There's a small increase in pedal travel but it's clear that the rear brakes are doing more work.
[Re: convx4]
#3153312
06/21/23 12:38 PM
06/21/23 12:38 PM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
There is also a 7/8” bore wheel cylinder that works with the 11” brakes. It can be used to reduce the braking power a bit to balance things out if the 11” drums lock up too early. Kind of similar to using an adjustable prop valve to balance the brakes out.Raybestos part number wc37236
I installed the 7/8 bore wheel cylnder with 11" drums on an 8 3/4 rear end that I built that went into a Scamp. The owner was happy with how it well worked. I used the 7/8" as well, this advise was given to me by Dr. Diff.
