Summit gas ported rings
#3150909
06/12/23 03:58 PM
06/12/23 03:58 PM
Posts: 4,687 Wichita
GY3
Wichita
Just a heads up for those looking to save some money.
The Summit branded gas ported rings are actually Total Seal and come with all the paperwork that says so in the box.
Re: Summit gas ported rings
[Re: HardcoreB]
#3151726
06/15/23 10:26 AM
06/15/23 10:26 AM
Posts: 8,171 Plymouth, MI
Blusmbl
Plymouth, MI
That's helpful, thanks! I've been pretty happy with all of the Summit branded stuff I've purchased so far, glad to hear they're sourcing from reputable companies.
[Re: Blusmbl]
#3151736
06/15/23 11:37 AM
06/15/23 11:37 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
That's helpful, thanks! I've been pretty happy with all of the Summit branded stuff I've purchased so far, glad to hear they're sourcing from reputable companies. Same here, the summit roller timing chain setup is exactly the same as Comp's kit and a good bit cheaper.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3151753
06/15/23 12:33 PM
06/15/23 12:33 PM
Posts: 19,376 Las Vegas
Al_Alguire
Las Vegas
The question is WHY use a gas ported ring? IMO its a bit of a gimmick for most. The ONLY place I could see using them is on a Stock Eliminator car since they are not allowed to use a gas ported piston.
[Re: Al_Alguire]
#3151763
06/15/23 01:17 PM
06/15/23 01:17 PM
GY3
Wichita
The question is WHY use a gas ported ring? IMO its a bit of a gimmick for most. The ONLY place I could see using them is on a Stock Eliminator car since they are not allowed to use a gas ported piston. Street car. Gas ports will get carboned up.
[Re: Al_Alguire]
#3152023
06/16/23 12:02 PM
06/16/23 12:02 PM
Posts: 3,521 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
The question is WHY use a gas ported ring? IMO its a bit of a gimmick for most. The ONLY place I could see using them is on a Stock Eliminator car since they are not allowed to use a gas ported piston. I have no experience with them but Total Seal says they make more horsepower than gas ported pistons. I think they have a video to support their claims. Bill
[Re: 340Cuda]
#3152025
06/16/23 12:22 PM
06/16/23 12:22 PM
Al_Alguire
Las Vegas
They make same claims about gapless stuff as well...Let me know how many serious race engines run those . Also let me know how many ported ring sets you find on those same serious and heads up cars. They are NOT new. I spend a fair amount of time around stuff that makes power. And the ONLY place we have ever used a ported ring is in a stocker...The reason because they are not allowed a gas ported piston...BTW there comparisons against a gas ported piston are ones with LATERAL gas ports. Most all agree that's not the hot ticket..
[Re: Al_Alguire]
#3152029
06/16/23 12:28 PM
06/16/23 12:28 PM
Posts: 2,926 A shed in England
Tig
A shed in England
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: dthemi]
#3152391
06/17/23 09:01 PM
06/17/23 09:01 PM
GY3
Wichita
The ones I saw where I commented on the packaging are going in a friend's turbo LS.
I haven't purchased any and not sure if I will.
[Re: dthemi]
#3153466
06/21/23 11:51 PM
06/21/23 11:51 PM
Posts: 4,457 Washington
madscientist
Washington
A ring of varied thickness will not have even tension. Also the difference in thickness effects heat absorbed by the ring, and adds more potential failure points. So you’ve seen first hand the “uneven” tension? Or failures? I have 3 sets out there now, all with no less than 2 years on them without failure.
[Re: dthemi]
#3154091
06/24/23 10:08 PM
06/24/23 10:08 PM
Posts: 3,087 Michigan
A727Tflite
Yes, the bore shows a pattern similar to the grooves in the rings, and ive seen them broken. Might be a good thing for a mild motor, but no place for a race engine. Would be interesting to see some examples, images of the bores and broken rings.
[Re: dthemi]
#3154099
06/24/23 11:35 PM
06/24/23 11:35 PM
GY3
Wichita
So they don't rotate in the bore like conventional rings do?
[Re: dthemi]
#3154136
06/25/23 09:04 AM
06/25/23 09:04 AM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Yes, the bore shows a pattern similar to the grooves in the rings, and ive seen them broken. Might be a good thing for a mild motor, but no place for a race engine. You got other problems with your rings not rotating, they would also have a bunch of blowby if they are making marks in the bore. I have done a bunch of dyno work of 2 barrel imca engines and they are required to run "stock" size rings. So they run 5/64 gas ported rings. The rings make about 8 hp, mid-range torque came up also. That is just over 2%. The engines had slightly less blowby during break-in (< .5 cfm). The owners do a leak down on the engines after every race, and so far no issues. Joe
Without Data, you’re just another guy with an opinion.
[Re: GY3]
#3154344
06/26/23 12:40 PM
06/26/23 12:40 PM
Posts: 4,070 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
The question is WHY use a gas ported ring? IMO its a bit of a gimmick for most. The ONLY place I could see using them is on a Stock Eliminator car since they are not allowed to use a gas ported piston. Street car. Gas ports will get carboned up. Goodson makes a hand held jig for less than $100... you can use it to radially gas port all the pistons your heart desires!
