Re: Radial tire issue ??
[Re: kevinlc]
#3150302
06/10/23 07:00 PM
06/10/23 07:00 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
First time out this year with the big block dart. Makes 820 hp with a stock front suspension and four link rear. Ran it for years with bias tires on all fours and no issues. This year I put on the good year rear radials. They’re a tad smaller than the 14x32 good year bias. There 31.5. With 17 lbs of air pressure. When I get to the 1/8 mile the steering wheel starts going left to right and the car starts rocking back and forth and I have to let out of it or I’ll wreck. It’s not tire shake, I’ve had that a couple of times but that was a the starting line. Anyone have any thoughts on the issue? Thanks for your input. . Do you still have the bias ply tires on the front?
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: kevinlc]
#3150394
06/11/23 07:28 AM
06/11/23 07:28 AM
Posts: 290 Long Island, NY
ValiantRich
Long Island, NY
I run M/T radials on my Valiant 14x32 with 15 lbs of air with no issues. Fronts are M/T bias. They are recommended for Super Stock. The Goodyear 14x32 radial is recommended for a much lighter car like comp eliminator . Maybe this is the problem or maybe it is something else entirely. Car runs mid 8 seconds
[Re: kevinlc]
#3150406
06/11/23 08:58 AM
06/11/23 08:58 AM
Posts: 2,924 A shed in England
Tig
A shed in England
Not much help I'm afraid but we've ran radial / bias fronts for many years with no issues, car is actually more stable than bias all round. Only doing 140 -145 at the moment. However, I have it in the back of my mind that radials are less forgiving than bias ply's when it comes to alignment issues but can't remember where I saw or heard that, Guessing that you've already checked tyre circumference, roundness etc when inflated.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3150491
06/11/23 12:52 PM
06/11/23 12:52 PM
Posts: 19,464 north of coder
moparx
how much caster do you have now ? maybe adding adding a couple more degrees along with a little more toe-in might help. i have mixed and matched radial and bias-ply on each end countless times without any problems, provided air pressure was correct and front alignment was spot on.
[Re: kevinlc]
#3150653
06/11/23 10:05 PM
06/11/23 10:05 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
First time out this year with the big block dart. Makes 820 hp with a stock front suspension and four link rear. Ran it for years with bias tires on all fours and no issues. This year I put on the good year rear radials. There a tad smaller than the 14x32 good year bias. There 31.5. With 17 lbs of air pressure. When I get to the 1/8 mile the steering wheel starts going left to right and the car starts rocking back and forth and I have to let out of it or I’ll wreck. It’s not tire shake, I’ve had that a couple of times but that was a the starting line. Anyone have any thoughts on the issue? Thanks for your input. I had this exact problem running 14x32 radial slicks twenty years ago. I would check with a couple of sources for help Fist, the tire manufacturer. Then go to a SuperStock forum and ask.
[Re: kevinlc]
#3150729
06/12/23 08:18 AM
06/12/23 08:18 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Bias ply tires up front w/ radials out back is not your problem. I've been 156+ mph w/ a stock suspension 3800 lb car w/ 295-65 radials (15x8 wheels) on the rear and bias ply M/T Sportsmans up front. The car drove perfectly fine.
[Re: an8sec70cuda]
#3150736
06/12/23 08:49 AM
06/12/23 08:49 AM
Posts: 2,513 PA
moparacer
PA
Is the problem originating in the front or the rear? From your description it sounds like the front is causing it due to alignment problems. Wheel starts moving....Bump steer issues? I would check that out first.
I have a hard time believing a radial slick would be more unstable than a bias all things being equal.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: an8sec70cuda]
#3150737
06/12/23 08:50 AM
06/12/23 08:50 AM
gregsdart
Bias ply tires up front w/ radials out back is not your problem. I've been 156+ mph w/ a stock suspension 3800 lb car w/ 295-65 radials (15x8 wheels) on the rear and bias ply M/T Sportsmans up front. The car drove perfectly fine. not the same, trust me. He has a 14 inch wide tire, which i believe is part of the issue . i went 8.78 at 153 mph and almost lost it due to "radial rock" like the author discribes. 3000 lb Dart. The car ocilates side to side violently. And when guys watching your 8.78 run ask why you didn't lift, it is very serious!
