Better shifter cable option than Hurst?
#3150718
06/12/23 06:57 AM
06/12/23 06:57 AM
Posts: 4,689 Wichita
GY3
Wichita
I have a Hurst Quarter Stick. It's worked flawless for over 8 years. I did have a heat sleeve ziptied around it but this weekend it got a little too hot and got really tight in some areas that weren't well protected.
Before I buy a replacement cable, is there a better option out there? I'm definitely putting a new heat sleeve on the new one.
Re: Better shifter cable option than Hurst?
[Re: topside]
#3150787
06/12/23 11:32 AM
06/12/23 11:32 AM
Posts: 2,515 PA
moparacer
PA
I don't know if they're interchangeable w/Hurst's, but the cables on my Cheetah shifters have been bulletproof for 25 years. I do run firesleeve over them if they're near exhaust, but otherwise they've been maintenance-free. We have always said that the Cheetah's are "the last shifter you will ever have to buy...." All that were put in our cars 30 years ago are still going strong.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: DusterKid]
#3150819
06/12/23 01:04 PM
06/12/23 01:04 PM
Posts: 34,928 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
My B&M prostick is sticking now too .. I need to find a longer / mew cable for it .. Luckily , I found a new PPP for a discounted price for Valiant https://precisionperformance.com/performance-shifters/Not a fan of the turbo action it goes from low to high all by itself
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#3150825
06/12/23 01:17 PM
06/12/23 01:17 PM
Posts: 11,621 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Morse cable. Someone makes/made a kit to replace the cheesy cable Hurst supplies. B&M uses/used a Morse cable on their version of this shifter.
Been a while, but I would fab/buy whatever I needed to make the Morse work. Otherwise, I like the Quarter Stick/Pro Stick shifters.
The garbage truck shifter, not so much. I get tired of fooling with air shifter pressures and gates to make them work for guys who think they are great.
