E-body leaf spring reinforcing plates #3150312
06/10/23 07:43 PM
06/10/23 07:43 PM
Minnesota
RROD Offline OP
RROD  Offline OP
Minnesota
Installing rear torque boxes in 70 E-body. I’ve seen pictures where they have two reinforcing plates sandwiching the forward leaf spring hangar attachment area. Anyone know the thickness of those particular plates?
Re: E-body leaf spring reinforcing plates [Re: RROD] #3150351
06/10/23 10:13 PM
06/10/23 10:13 PM
AndyF Offline
AndyF  Offline
Re: E-body leaf spring reinforcing plates [Re: AndyF] #3150373
06/11/23 12:28 AM
06/11/23 12:28 AM
Minnesota
RROD Offline OP
RROD  Offline OP
Minnesota
Yes those plates. Looks easy enough to make. Would like to know what thickness of material was used for plates.
Re: E-body leaf spring reinforcing plates [Re: RROD] #3150481
06/11/23 12:23 PM
06/11/23 12:23 PM
moparx Offline
moparx  Offline
3/16" would be plenty, but 1/4" would be most likely easier to source locally.
beer
Re: E-body leaf spring reinforcing plates [Re: RROD] #3150487
06/11/23 12:32 PM
06/11/23 12:32 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Write the check, they will be at your door before the check clears, and Andy will be able to eat this week ...
It takes gasoline to interest me.
Re: E-body leaf spring reinforcing plates [Re: VL21] #3150488
06/11/23 12:39 PM
06/11/23 12:39 PM
moparx Offline
moparx  Offline
that is correct. ^^^^^^^^^^^^^^^^^^^
by the time a guy sources the material, cuts the plates to size, measures and lays out the bolt patterns, drills the holes, remove any burrs, clean/prep/paint the plates, you are looking at way more than what andy is asking for his plates !
if the material is on hand and one is a fabricator and enjoys doing everything himself, one could entertain fabricating those plates.
if not, buy andy's ! up
beer
Re: E-body leaf spring reinforcing plates [Re: moparx] #3150622
06/11/23 08:36 PM
06/11/23 08:36 PM
Minnesota
RROD Offline OP
RROD  Offline OP
Minnesota
Ok, but should there be two plates that sandwich the spring bracket attachment structure? (A flat plate without the center hole welded to the outside structure and the plate with the center hole welded to the inside).
Re: E-body leaf spring reinforcing plates [Re: RROD] #3150668
06/11/23 11:17 PM
06/11/23 11:17 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
So reinforce the base plate but leave existing studs the same?
Re: E-body leaf spring reinforcing plates [Re: PhillyRag] #3150836
06/12/23 01:35 PM
06/12/23 01:35 PM
moparx Offline
moparx  Offline
one can use two plates, but before you start, make sure your studs are going to be long enough to have at least a couple of threads protruding through the nuts when tightened down.
beer
Re: E-body leaf spring reinforcing plates [Re: moparx] #3150974
06/12/23 07:23 PM
06/12/23 07:23 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Just did this very thing with 2 plates on each side on my Son in Laws Dumpster to fit 275's in the wheel wheel better.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
