Dodge aircraft tug --NoDak #3150046
06/09/23 03:39 PM
06/09/23 03:39 PM
S.E. South Dakota !
bigdad Online content OP
Still Posting A Lot
bigdad  Online Content OP
Still Posting A Lot
S.E. South Dakota !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Dodge aircraft tug --NoDak [Re: bigdad] #3150223
06/10/23 12:28 PM
06/10/23 12:28 PM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
NO WAY the miles and hours match up on this. These things were geared to pull 40-60,000 pounds and max out at 20-25 mph. Even at 25 mph CONSTANT speed it should have over 500 hours. On top of that, these things got a TON of idle time sitting on the flight line. They were used primarily for Aerospace Ground Equipment like heaters, generators, and maintenance gear, and ended up as the only place to warm up... Being this old, it might have come from a Guard or Reserve base and be in decent shape, but usually they were pretty far gone.
Re: Dodge aircraft tug --NoDak [Re: nuthinbutmopar] #3150237
06/10/23 01:42 PM
06/10/23 01:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The hour meter records the engine running time so, when it's sitting with the engine running, it's recording time but not miles.
Re: Dodge aircraft tug --NoDak [Re: nuthinbutmopar] #3150243
06/10/23 02:16 PM
06/10/23 02:16 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
See the "AMMO" sticker on the back window? We use them to haul trailers back and forth to/from the flightline and in the bomb dump. They don't get near the use in the bomb dump as they do when used exclusively for aircraft support.
Having said that, just because it was last used in the bomb dump doesn't mean it spent all of its life there. twocents
Re: Dodge aircraft tug --NoDak [Re: Fat_Mike] #3150252
06/10/23 02:38 PM
06/10/23 02:38 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
The ackerman wasn't changed for the shorter wheelbase. These things eat front tires like crazy.
devilA neutral drop will create wheelies whistling
Re: Dodge aircraft tug --NoDak [Re: A990] #3150354
06/10/23 10:32 PM
06/10/23 10:32 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
No doubt, and ALL of them were rode hard...regardless of which unit they were assigned to.
Re: Dodge aircraft tug --NoDak [Re: Fat_Mike] #3150391
06/11/23 06:55 AM
06/11/23 06:55 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
So what's this low mile Cummins and all the junk that comes with it worth? shruggy
Re: Dodge aircraft tug --NoDak [Re: A990] #3150623
06/11/23 08:37 PM
06/11/23 08:37 PM
Central Michigan
N
N
Central Michigan
Ever work on a Jeep bobtail with the Nissan forklift diesel? First the AGE guys figured out they could remove the steering stops on the front axle to turn sharper. So much flex that they'd get cracks cross the back of the cab from body mount to body mount; TCTO to inspect and repair, plus reinstall the stops and weld them in place. Then they found out that the Jeeps didn't have a super-high rear axle ratio, just a transfer case with no shifter and a plate to lock it in low range. With one 3/8" bolt holding the plate on. Pull the bolt off, use the plate to shift it into "high" and they'd run 50+ mph. They rolled one on midnights at Mildenhall...
