Opinions on Truetrac
#3149923
06/09/23 09:10 AM
06/09/23 09:10 AM
Posts: 421 Australia
fullonmopar
Australia
Considering using the Truetrac limited slip centre in my 8 3/4 diff, anybody with any experience with them good and bad. Thanks from down under.
Re: Opinions on Truetrac
[Re: fullonmopar]
#3150206
06/10/23 10:53 AM
06/10/23 10:53 AM
Posts: 12,080 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have has one in the Cuda for a few years now. No track time but I run drag radials. Has been fine, but I haven't been really hard on it either.
Master, again and still
[Re: A990]
#3150322
06/10/23 08:39 PM
06/10/23 08:39 PM
Posts: 5,818 ohio
ruderunner
ohio
I'm a fan of Detroits. Not that I've ever heard anything bad about the Trutrac, but I'm used to how Detroits act and I'm ok with their quirks.
Angry white pureblood male
[Re: 83hurstguy]
#3150539
06/11/23 04:54 PM
06/11/23 04:54 PM
Posts: 1,552 Michigan
Kiddart
I have one from Dr. Diff and it has been absolutely flawless!!!
Thank you Kiddart
[Re: fullonmopar]
#3150926
06/12/23 04:44 PM
06/12/23 04:44 PM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
I put one in a friends 8.8 Ford rear , I don't remember if we used synt. oil or dino juice but when we went to do an oil change after about 15k miles mostly daily driver miles with some drag racing behind a stick trans, the oil was filled with metal particles. He had 2 rears so we swapped the stock one back in and when I went to take it apart to see what the issue was I couldn't get one of the C clips out , had to do some grinding and after getting out the clip I had to beat the axle out of the diff. When I finally got it out I disassembled the unit and best I could tell was the unit was put together backwards, we used it right out of the box , and the thrust of the helical gears was being applied against the the wrong side of the diff housing and was grinding it self up. He called Eaton and they said sorry, but you can buy another ... it was over a year since buying it. I still have the unit, I'll dig it out and get some pictures ...
We replaced it with a grizzly locker and put a set of road race locker springs in it so it wasn't as harsh on the street if it was damp out , daily driver.
I would either use a clutch type or a grizzly/Detroit locker before any trutrack.
[Re: Kiddart]
#3151464
06/14/23 12:08 PM
06/14/23 12:08 PM
Posts: 21,645 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
I have one from Dr. Diff and it has been absolutely flawless!!! I am considering ordering a dana 60 from Cass and was thinking this might be the way to go. I figured by the time I ordered everything for the 8 3/4, I could just go all-in and get the dana.
[Re: fullonmopar]
#3151682
06/15/23 12:52 AM
06/15/23 12:52 AM
Posts: 704 USA
rftroy
USA
Talk to Dr. Diff. You'll see on his website that he no longer carries the Eaton Truetrac due to quality issues. I bought one several years ago, and it was junk. From what I could find it seemed to only be a problem with the MOPAR 8 3/4 version. It's been a while, but I'm pretty sure the problem was with end play in the side gears. They're supposed to be a tight fit in the case, but the one I got had 0.045" end play in one of the side gears. That means that gear would be constantly banging back-and-forth by 0.045" every time you accelerated or decelerated. I bought one of Dr. Diff's proprietary units, the Sure-Trac II. As I recall, (check with him to see if I recall correctly ) he makes them from Ford 9 inch units, which he orders unfinished and machines them to fit 8 3/4 bearings and ring gears. Here is the link that was provided above by 83hurstguy: https://www.doctordiff.com/8-3-4-helical-gear-sure-grip-sure-trac.htmlBottom line, I definitely do not recommend the Eaton Truetrac. Robert
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: chargerbr549]
#3151686
06/15/23 01:06 AM
06/15/23 01:06 AM
Posts: 28,596 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I dont have any experience with a Trutrac but I like to use the Powerlok differential like the 68 and older 8 3/4's used, you can set them up aggressive or normal depending on how you want it. Dr Diff has reproduced them so you might think about these unless you have already made your decision. https://www.doctordiff.com/8-3-4-clutch-type-sure-grip-powr-lok.html Out of stock for quite some time now. I wanted one and a offset spring kit no dice on both.
[Re: Kiddart]
#3152571
06/18/23 10:21 PM
06/18/23 10:21 PM
Posts: 294 Maryland
MoparMike1974
Maryland
I have a tru trac in my swinger and have had no problems with it. I talked to dr diff after seeing his post about having problems with them. The issue with them was tolerances and they would wine. I asked if I was going to have issues down the line and he said if there was a problem it would be obvious right away. I dont have many miles on it but so far so good. The second one I bought from him was the one he had made. I haven't installed it yet but it looks like a really well made part.
