‘07 Charger No Start #3149783
06/08/23 04:41 PM
06/08/23 04:41 PM
IN
GTX4spd Offline OP
GTX4spd  Offline OP
IN
My grandaughter’s ‘07 Charger R/T alternator locked up last week, I replaced the alt & associated parts plus put in a new battery. Thought it would be good to go but no. I have lights, etc, but the starter doesn’t do anything. The warning lights for the Electronic Throttle Control & Voltage are lit. I’ve checked fuses, found nothing. And checked my connections from the original work & found no problems. Pulled codes UO100 & U110B but don’t think those are the cause of no-start. Is it the PCM? Any ideas?
"Gentlemen, we must all hang together, or surely, we shall all hang seperately."--Benjamin Franklin www.wwnboa.org if you're interested in '62-'74 B-Bodies
Re: ‘07 Charger No Start [Re: GTX4spd] #3149801
06/08/23 07:40 PM
06/08/23 07:40 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Will it shift into neutral?
Facts are stubborn things.
Re: ‘07 Charger No Start [Re: larrymopar360] #3149839
06/08/23 09:16 PM
06/08/23 09:16 PM
IN
GTX4spd Offline OP
GTX4spd  Offline OP
IN
Yes, the shifter moves, I tried numerous times to start it in neutral.
Re: ‘07 Charger No Start [Re: GTX4spd] #3149853
06/08/23 09:55 PM
06/08/23 09:55 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
How about a security system activated. You might have to reset it after removing the battery. You should be able to find reset instructions online.
Re: ‘07 Charger No Start [Re: GTX4spd] #3149886
06/09/23 12:34 AM
06/09/23 12:34 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Looking online what I found.
Quote
Error code U0100 means the PCM cannot send or receive communication signals via the CAN bus. DTC U0100 code usually comes up due to the following: Faulty ECM. Problem with control module wiring.
That could be your problem.
The other one is
Quote
U110B Code - Lost Engine Coolant Message
Read more: https://www.autocodes.com/u110b.html
BTW, if it ends up that it's an engine wire harness problem I have the one that I just took off my wife 2006 Charger Daytona that I just finished up installing a 6.4 stroker and I used an SRT wiring harness from a 6.1 on it so I have the original one available.
Re: ‘07 Charger No Start [Re: SNK-EYZ] #3149900
06/09/23 06:44 AM
06/09/23 06:44 AM
IN
GTX4spd Offline OP
GTX4spd  Offline OP
IN
Car doesn’t have a security system, although that was a good thought that wouldn’t have occurred to me.
Thanks for the wiring offer, if I find that to be the problem I’ll be contacting you.
Re: ‘07 Charger No Start [Re: GTX4spd] #3150010
06/09/23 01:41 PM
06/09/23 01:41 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
They all have some basic security system as in SKIM key, meaning that the chip in the key controls if it will actually start and run.
It will crank though even if the key isn't programmed.
I believe it will even run for something like 5 seconds with an un-programmed key.
Re: ‘07 Charger No Start [Re: SNK-EYZ] #3150061
06/09/23 04:34 PM
06/09/23 04:34 PM
IN
GTX4spd Offline OP
GTX4spd  Offline OP
IN
I was thinking aftermarket security, but there’s no action at all from the starter. I’m currently trying to find a fusible link that is supposedly between the starter and alternator. Just another path to trod.
Re: ‘07 Charger No Start [Re: GTX4spd] #3150066
06/09/23 04:55 PM
06/09/23 04:55 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
This video might help.
It goes through diagnosing the starter system on a 2007 Charger.
https://www.youtube.com/watch?v=H37G08uqsBA&ab_channel=LehewTech
Re: ‘07 Charger No Start [Re: SNK-EYZ] #3150255
06/10/23 02:53 PM
06/10/23 02:53 PM
IN
GTX4spd Offline OP
GTX4spd  Offline OP
IN
Thanks I’ll look at it now.
Re: ‘07 Charger No Start [Re: GTX4spd] #3150479
06/11/23 12:19 PM
06/11/23 12:19 PM
moparx Online content
moparx  Online Content
please let us know what you find.
beer
