NEED INFO/PICTURES.71 CUDA INSTALLATION OF HEADLIGHT BUCKETS #1950488
11/13/15 02:05 PM
11/13/15 02:05 PM
Sweden
71redcuda Offline OP
Sweden
Im looking for mounting instructions for the headlight bucket plates for 71 cuda.. need picture how they are mounted against the "fender side".. The other side (closest to the radiator is mounted with "L" brackets...
And the side closest to the fender is mounted with bolts.. but should it be any distance or is the "headlight bucket plate" bolted right on w/o distance?
Nicklas
Re: NEED INFO/PICTURES.71 CUDA INSTALLATION OF HEADLIGHT BUCKETS [Re: 71redcuda] #1951024
11/14/15 12:46 PM
11/14/15 12:46 PM
Canada
ACR2000 Offline
ACR2000  Offline
Canada
Hi Nicklas, these might help you
Stephan
Re: NEED INFO/PICTURES.71 CUDA INSTALLATION OF HEADLIGHT BUCKETS [Re: ACR2000] #1951087
11/14/15 03:04 PM
11/14/15 03:04 PM
Sweden
Sweden
Thank you!
Re: NEED INFO/PICTURES.71 CUDA INSTALLATION OF HEADLIGHT BUCKETS [Re: 71redcuda] #3149443
06/07/23 04:14 PM
06/07/23 04:14 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Thank you!
