Flex Plate Question #3148811
06/05/23 10:37 AM
06/05/23 10:37 AM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I've been planning on using a factory 764 torque converter with the 727 on my 400/470. Some years back I bought a new MP SFI rated flex plate which I had not used yet so I thought I would use it finally with this engine/trans. I hadn't noticed till yesterday that the flex plate has 7/16" bolt holes and the lugs on the torque converter are 5/16". I would rather use another flex plate than invest in another torque converter so my question is, would a factory flex plate (the original from the 400 which I have) be o.k. to use with this engine/trans. combo or is the motor going to have too much power for a factory flex plate? If I shouldn't use a factory plate, does anyone make a flex plate for higher horsepower applications that has 5/16" bolt holes? The car will be street driven only as I have no plans to take the car racing at the track.
Re: Flex Plate Question [Re: 6PAX] #3148848
06/05/23 12:42 PM
06/05/23 12:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
IMO, the factory flexplate will be just fine. The B&M #10230 has multiple bolt holes for both bolt circles and the large and small bolts.
Re: Flex Plate Question [Re: 6PAX] #3148867
06/05/23 01:19 PM
06/05/23 01:19 PM
Mopar made three different 6 bolts for the crankshafts stock production flex plates, 12.0 inch with the 5/16 bolt and a 11.0 with the same bolts as well as a 11.0 with the lager 7/16 bolts for the Hi Po motors like the 426 M.W and 440 magnums with the smaller 11.0 inch Hi Po converters.
A lot of the early, pre1969 I think, Hi Po 375 HP 440 motors came with the 12.0 inch converters with the smaller 5/16 converter bolts also confused
Re: Flex Plate Question [Re: Cab_Burge] #3149201
06/06/23 07:36 PM
06/06/23 07:36 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Well, I was going to go with the factory flex plate but it turns out the bolt pattern doesn't match the converter. The bolt holes are 11" apart on the plate and 10" on the converter so I guess I will have to buy another flex plate afterall.
Re: Flex Plate Question [Re: 6PAX] #3149298
06/07/23 08:52 AM
06/07/23 08:52 AM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Re: Flex Plate Question [Re: 6PAX] #3149359
06/07/23 11:37 AM
06/07/23 11:37 AM
Missouri
randavis Offline
randavis  Offline
Missouri
I have a PRW on my 511" RB. It's an 8 bolt crank. The flex plate has holes for about any converter out there. It's been on there since 2021. No issues with it.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: Flex Plate Question [Re: 6PAX] #3149363
06/07/23 11:49 AM
06/07/23 11:49 AM
A727Tflite Online content
A727Tflite  Online Content
Originally Posted by 6PAX
The 1831800 looks like it might be a B & M copy.
Re: Flex Plate Question [Re: A727Tflite] #3149380
06/07/23 12:48 PM
06/07/23 12:48 PM
moparx Offline
moparx  Offline
that was my thought as well.
beer
Re: Flex Plate Question [Re: 6PAX] #3149422
06/07/23 03:06 PM
06/07/23 03:06 PM
you have a PM from me on this scope up whistling
Re: Flex Plate Question [Re: randavis] #3149922
06/09/23 09:10 AM
06/09/23 09:10 AM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Which PRW plate do you have?
Re: Flex Plate Question [Re: 6PAX] #3149977
06/09/23 12:09 PM
06/09/23 12:09 PM
Missouri
randavis Offline
randavis  Offline
Missouri
P/N 1841310 Platinum series. It's SFI spec 29.1 rated for 3 years.
Re: Flex Plate Question [Re: randavis] #3149980
06/09/23 12:15 PM
06/09/23 12:15 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Thanks.
