Trans won't move (Issue Fixed) #3148024
06/01/23 05:12 PM
06/01/23 05:12 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Just wanted to share a strange issue that I've been having for a LOOOONG time, and finally resolved.
About 3 years ago my car would have a strange issue where upon start up after sitting, the car would act like it was in neutral in any gear. Waiting 10-15 seconds would fix it, and the car would work completely normal. Many 9 second passes, just an odd thing.
Then Two years ago I had an issue where the 60fts had really dropped off, but the car would still MPH well. I had originally thought this was because of a stuck TCCV (Torque converter fill valve). The converter wasn't filling, which explained my neutral in any gear for 10-15 seconds, and a converter low on fluid won't couple well at the starting line. More RPM could fill it and fix it at the finish line.
However upon futher inspection, I realized that some aftermakret valvebodies actually bypass this valve. So even though mine was stuck, it was essentially a dummy plug and had no function. I then thought it might be the trans cooler or lines being partially plugged, because the converter fill/empty circuit runs through the lines. I cleaned them out well, and moved forward.
A few weeks ago the first time out with the new motor, the car was on the rev limit the last 300ft of the track. A few more tries and it just kept getting worse. I put the car in the trailer and went home, only to find out when I got there the car would not move at all again in any gear.
Well yesterday I FINALLY found the issue. The upper casting of the valve body is cracked in the pressure circuit. A big enough bleed here will cause no converter fill, which is exactly what was happening. I can only assume it's been there for a very long time, and has just continually gotten worse.
So hopefully this long 3 year saga will help somebody some day fix the issue!
Re: Trans won't move (Issue Fixed) [Re: dizuster] #3148031
06/01/23 05:41 PM
06/01/23 05:41 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Interesting - can't say I've seen that before.
Re: Trans won't move (Issue Fixed) [Re: topside] #3148041
06/01/23 06:30 PM
06/01/23 06:30 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
A gentleman that I ported a set of heads for over the winter told me that when I drive my 2006 dodge diesel which I Dont drive very offer to start it up and let it run 15 seconds in neutral. It acts like a different truck when I do this simple trick.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Trans won't move (Issue Fixed) [Re: dizuster] #3148044
06/01/23 07:05 PM
06/01/23 07:05 PM
NY
B1duster Offline
B1duster  Offline
NY
727 in my brothers old dart did the very same thing. I never fixed it, and it never quit.
Motor and trans were eventually swapped out but I still have the trans and will have to take a look someday.
Re: Trans won't move (Issue Fixed) [Re: pittsburghracer] #3148045
06/01/23 07:07 PM
06/01/23 07:07 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
Yeah, thats because the converter drains back. The crack he has actually affects the pressure building up.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Trans won't move (Issue Fixed) [Re: Prodart440] #3148049
06/01/23 07:26 PM
06/01/23 07:26 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
That's such an oddball find, thanks for sharing! I take it most of the common aftermarket valve bodies start with factory castings?
Re: Trans won't move (Issue Fixed) [Re: dizuster] #3148412
06/03/23 02:10 PM
06/03/23 02:10 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Nice find up
Re: Trans won't move (Issue Fixed) [Re: dizuster] #3148630
06/04/23 04:13 PM
06/04/23 04:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Cracks in that area aren't common but....
