Re: Dana 60 axle housing end diameter
[Re: Air Grabbler]
#3147810
05/31/23 12:47 PM
05/31/23 12:47 PM
Posts: 25,802 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Just have a machine shop make a press-in sleeve to reduce the diameter of the oversized end. Easier and cheaper than replacing the ends.
[Re: John_Kunkel]
#3147822
05/31/23 01:27 PM
05/31/23 01:27 PM
Posts: 19,406 north of coder
moparx
that was going to be my suggestion as well. when the sleeve is pressed in, watch how the axle goes in. if a bit of jiggering around is necessary, it might be a good idea to check that tube to see if it's bent. also, it's common for a pressed in sleeve to "shrink" a couple thousands of an inch on it's inside diameter when installed [depending upon the amount of "press" fit] thus, requiring a slight hone to the desired fit clearance. a way easier [and cheaper] fix than installing a new bearing end.
[Re: John_Kunkel]
#3147827
05/31/23 01:38 PM
05/31/23 01:38 PM
Posts: 4,722 Moved to N.E. Tennessee
GomangoCuda
That's going to be a pretty thin sleeve to press in. Might consider freezing it and dropping it in. A little red loctite would't hurt.
[Re: GomangoCuda]
#3147900
05/31/23 08:39 PM
05/31/23 08:39 PM
Posts: 8,270 fredericksburg,va
cudaman1969
fredericksburg,va
That's going to be a pretty thin sleeve to press in. Might consider freezing it and dropping it in. A little red loctite would't hurt. Like I said .030 shim 3/4” wide, 360 degrees, epoxy it in with an old cone, it’s tight.
