3.55 vs 3.91 track time differences? #3147457
05/29/23 04:11 PM
05/29/23 04:11 PM
Pittsburgh, Pa
Jeff_383 Offline OP
Jeff_383  Offline OP
Pittsburgh, Pa
All else being equal, would there be a change in 1/4 mile times going from 3.91 to 3.55?
3900lb b body, large cube stroker, same PTC 9.5 converter (built for car with 3.91's)
Re: 3.55 vs 3.91 track time differences? [Re: Jeff_383] #3147470
05/29/23 06:46 PM
05/29/23 06:46 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Just a guess, you may not lose much ET, maybe .05, but will probably pick up a little MPH.
Re: 3.55 vs 3.91 track time differences? [Re: Jeff_383] #3147471
05/29/23 06:52 PM
05/29/23 06:52 PM
AndyF Offline
AndyF  Offline
Can't really say without looking at the data log or some numbers. If the car is on the rev limiter going down the track then it might pick up time. If it is traction limited it might go quicker and faster with less gear. If the 3.91 gears are perfect for the engine and car then it will slow down.
Re: 3.55 vs 3.91 track time differences? [Re: AndyF] #3147476
05/29/23 07:17 PM
05/29/23 07:17 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Taller gear should raise the converter's stall speed a bit.
Whether the car wants that is hard to tell from here with the info so far.
Re: 3.55 vs 3.91 track time differences? [Re: AndyF] #3147477
05/29/23 07:19 PM
05/29/23 07:19 PM
Pittsburgh, Pa
Jeff_383 Offline OP
Jeff_383  Offline OP
Pittsburgh, Pa
I'm not really sure. The engine made 601 horsepower at 5500 and 633 torque at 4500
I know that's a vague answer, but I never really picked a gear to build on.
Re: 3.55 vs 3.91 track time differences? [Re: Jeff_383] #3147497
05/29/23 09:18 PM
05/29/23 09:18 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
With that kind of torque, I doubt you'll see much difference shruggy twocents
Re: 3.55 vs 3.91 track time differences? [Re: Jeff_383] #3147502
05/29/23 10:19 PM
05/29/23 10:19 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
What's the car running now with the 3.91?
Re: 3.55 vs 3.91 track time differences? [Re: A12] #3147511
05/29/23 11:42 PM
05/29/23 11:42 PM
Pittsburgh, Pa
Jeff_383 Offline OP
Jeff_383  Offline OP
Pittsburgh, Pa
I haven't ran it with the new motor yet. Old motor went mid 11's with the 3.91's.
Re: 3.55 vs 3.91 track time differences? [Re: topside] #3147792
05/31/23 11:59 AM
05/31/23 11:59 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Flash rpm yes, stall no. Rear gear has no effect on stall and it really only changes flash rpm because of how flash rpm is defined, not a “real” change to the actual flash rpm. The change is the car just moves easier/sooner. So yes the rpm will be lower when the car first moves, but you can still get to the power band quicker during the run. (The reason we play with flash in the first place)I went with a low gear set 904 which would “lower” my flash rpm, but because the car is moving, I would get to peak torque .5 second quicker in the run, even with the “reduced” flash rpm.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: 3.55 vs 3.91 track time differences? [Re: Jeff_383] #3147834
05/31/23 01:58 PM
05/31/23 01:58 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Nothing with that combo.
We run a 3.54 gear with a 505" stroker and rear ratio seems to matter very little with the torque it makes.
It's been 1.36 60 ft. with an 11" converter.
'63 Dodge 330
11.19 @ 121 mph
Re: 3.55 vs 3.91 track time differences? [Re: GY3] #3147899
05/31/23 08:39 PM
05/31/23 08:39 PM
[quote=GY3]Nothing with that combo.
We run a 3.54 gear with a 505" stroker and rear ratio seems to matter very little with the torque it makes.: iagree I ran 4 different rear gear ratios in my old pump gas stroker motor in my Duster, 3:73, 3,91, 4.10 and 4.30 with no other changes, other than running at different tracks. It ran within.08 and 1.0 MPH as long as it didn't spin work shruggy
I did have a Mopar brand low gear drive set (2.77 I think) in the 727, best 60 ft was 1.42 I think confused shruggy
Re: 3.55 vs 3.91 track time differences? [Re: Cab_Burge] #3147910
05/31/23 10:14 PM
05/31/23 10:14 PM
Pittsburgh, Pa
Jeff_383 Offline OP
Jeff_383  Offline OP
Pittsburgh, Pa
Well, I may look out for a 3.55 third member then. It does drive well with the 3.91's. Just want a little more on the freeway for some longer trips. I also really like the new PTC 9.5.
Re: 3.55 vs 3.91 track time differences? [Re: Jeff_383] #3147917
05/31/23 10:56 PM
05/31/23 10:56 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
If that's[/i] the goal (or the consideration), there are calculators that will tell you how much your RPM's will be affected. I think [i]the track will be the only way to truly figure out the affect at the track. shruggy
Re: 3.55 vs 3.91 track time differences? [Re: Jeff_383] #3147919
05/31/23 11:38 PM
05/31/23 11:38 PM
AndyF Offline
AndyF  Offline
If you want a higher gear for the freeway then go with the 3.55 gears. Sounds like the car is more of a driver than an all out drag car so make it work for what you want it to do. It isn't going to slow down much at the track. In fact, if it is traction limited then it might actually leave the line better with the taller gear.
Re: 3.55 vs 3.91 track time differences? [Re: Jeff_383] #3147945
06/01/23 09:01 AM
06/01/23 09:01 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Master, again and still
Re: 3.55 vs 3.91 track time differences? [Re: Jeff_383] #3147966
06/01/23 11:17 AM
06/01/23 11:17 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
You say "third member".
If you're planning on hooking this combo at the track with slicks, you're going to need to upgrade to something stouter than an 8 3/4.
'63 Dodge 330
11.19 @ 121 mph
Re: 3.55 vs 3.91 track time differences? [Re: GY3] #3148019
06/01/23 04:06 PM
06/01/23 04:06 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
That is a little deceiving. shruggy Unless you are saying you went 1.36 N/A.
On my 389 small block, I run a 3.55 gear and have gone 1.37 60ft.... but... there is more to that statement...
Re: 3.55 vs 3.91 track time differences? [Re: TheOtherDodge] #3148022
06/01/23 04:24 PM
06/01/23 04:24 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
1.54 60 ft. N/A
There, how's that? grin
'63 Dodge 330
11.19 @ 121 mph
Re: 3.55 vs 3.91 track time differences? [Re: GY3] #3148139
06/02/23 09:55 AM
06/02/23 09:55 AM
Houston, Texas
Houston, Texas
1.54 60 ft. N/A
LOL, much more applicable! boogie
Re: 3.55 vs 3.91 track time differences? [Re: TheOtherDodge] #3148180
06/02/23 12:14 PM
06/02/23 12:14 PM
Pittsburgh, Pa
Jeff_383 Offline OP
Jeff_383  Offline OP
Pittsburgh, Pa
Well, I did do a 1.58 60 with the old motor and 3.91's
