Re: 8 3/4 wheel bearing preload
[Re: allmopar]
#3147326
05/28/23 11:13 PM
05/28/23 11:13 PM
Posts: 43,259 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3147353
05/29/23 06:33 AM
05/29/23 06:33 AM
Posts: 5,917 ohio
ruderunner
ohio
Are you sure it's an open diff and not just a worn out Sure Grip?
Open should have a one piece thrust block, Sure Grip have thrust buttons on the block which are known to fall out when axles are pulled.
Either way, endplay should be the same on both sides. If the axles are butted against the thrust block, they essentially act like a single shaft all the way through.
Angry white pureblood male
[Re: allmopar]
#3147417
05/29/23 12:24 PM
05/29/23 12:24 PM
Posts: 5,917 ohio
ruderunner
ohio
We all have those moments.
The good news is that grease is pretty easy to contain. You might not need to go after the seal. Considering how much of a PITA and expense that is, I'd take the gamble.
[Re: fastmark]
#3148141
06/02/23 10:11 AM
06/02/23 10:11 AM
Posts: 5,917 ohio
ruderunner
ohio
Hey now, I don't qualify as senior yet.
