Re: headers glowing red at idle
[Re: dart games]
#3147175
05/28/23 09:00 AM
05/28/23 09:00 AM
Posts: 2,937 A shed in England
Tig
A shed in England
My first guess would be ignition timing, then cam timing. Verify both. Let us know when you find the issue.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3147180
05/28/23 09:22 AM
05/28/23 09:22 AM
Posts: 10,763 North Dakota
6PakBee
North Dakota
I'd bet on ignition timing also. Having the distributor locked at a certain figure (34/36 in this case) is NOT the same as initial timing. Think of this for a minute, I would doubt you could even get it started if you had 34 degrees initial timing.
[Re: dart games]
#3147181
05/28/23 09:25 AM
05/28/23 09:25 AM
Posts: 173 Sticky South
Rodenteliminator
Sticky South
Buying one complete have the seller put it on stand and and check as much as possible or if they don’t want to do that start deducting or walk away, it could cost you in the long run. Doug
Sorry honey I spent the rent
[Re: dart games]
#3147183
05/28/23 09:52 AM
05/28/23 09:52 AM
6PakBee
North Dakota
6 pacbee.i had plenty of drag motors with locked distributors at that timing and worked ok.it fires ok.and revs up ok but cant get to idle no matter what i do to the carb and headers glow red.when that happens i shut it down and let cool Don't know what to tell you then.
[Re: B1MAXX]
#3147192
05/28/23 10:26 AM
05/28/23 10:26 AM
Posts: 20,217 Park Forest, IL
slantzilla
Park Forest, IL
Could the stock timing cover marks be off with the ATI damper?
[Re: slantzilla]
#3147198
05/28/23 10:55 AM
05/28/23 10:55 AM
fast68plymouth
So. Burlington, Vt.
The reason for the compression test was to perhaps shed some light on the cam timing situation.
If it was way low you’d have reason to suspect the cam was retarded.
[Re: dart games]
#3147201
05/28/23 11:23 AM
05/28/23 11:23 AM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
Make sure the distributor pickup coil is not wired backwards.
[Re: dart games]
#3147218
05/28/23 12:17 PM
05/28/23 12:17 PM
Posts: 5,167 CT
GTX MATT
CT
Alright so figure out if the vacuum leak is between the carb and intake, intake and heads, or someplace else. Try carb clean/starting fluid trick
[Re: rickraw]
#3147313
05/28/23 10:17 PM
05/28/23 10:17 PM
Posts: 8,186 Plymouth, MI
Blusmbl
Plymouth, MI
Definitely try carb cleaner or something near the intake to head area, underside by the valley pan, and around the base of the carb.
Like others have mentioned, it’s either too lean or the timing is retarded. You’ve verified the timing mark with a piston stop so that is likely ruled out, but if it doesn’t die with your hand covering the carb it sounds like it’s getting excess air somewhere.
