Voltage regulator ID needed #3146691
05/24/23 09:07 PM
05/24/23 09:07 PM
MI
I
IROC78 Offline OP
IROC78  Offline OP
I
MI
I was hoping someone might be able to identify this voltage regulator for me. Part number on back reads 4336A11. Any help is greatly appreciated. Thanks,
Re: Voltage regulator ID needed [Re: IROC78] #3146692
05/24/23 09:11 PM
05/24/23 09:11 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
Aftermarket solid state relay, for pre 1970 car. I did a search and think they are no longer available. You can use a solid state repop. https://www.ebay.com/itm/1857082801...c0KSP_wIVbm1vBB02EgcgEAQYASABEgLFwfD_BwE
Re: Voltage regulator ID needed [Re: IROC78] #3146693
05/24/23 09:12 PM
05/24/23 09:12 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Some sort of aftermarket.
Re: Voltage regulator ID needed [Re: IROC78] #3146696
05/24/23 10:06 PM
05/24/23 10:06 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Likely a wells/ aitex 1V1067
oreillys shows MasterPro Ignition 12 Volt Voltage Regulator, Line: MPI Item: 2VR9 solid state
Advance crarquesst Part # RAA1052 Odd looking
Autozone Duralast Voltage Regulator VR706 same as above beer
Re: Voltage regulator ID needed [Re: TJP] #3146742
05/25/23 08:05 AM
05/25/23 08:05 AM
MI
I
IROC78 Offline OP
IROC78  Offline OP
I
MI
Thank you for the replies. TJP seems to have hit it on the head as a google search of his suggestion returns a picture that looks identical. Thank you again everyone I really appreciate it.
Re: Voltage regulator ID needed [Re: IROC78] #3146857
05/25/23 10:44 PM
05/25/23 10:44 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up beer
