Re: How do I remove "tamper-proof" idle plugs?
[Re: TJP]
#3146495
05/23/23 11:23 PM
05/23/23 11:23 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
I'll post some pics tomorrow if you really want them... but in brief, for each adjustment (my carb has 2, but some have 4) there is a boss cast into the baseplate. Each has a welch plug about 5/16" in diameter, installed backwards (lip toward the carb) so I can't just grab it with a screw extractor. Behind the plug is the idle mixture screw, which has a special head, although I've read that the right size Allen wrench will work.
This carb originally came off a '86 or '87 Ford truck, with either a 351W or 460. The primary bowl actually has cast into it, "Manufactured by Holley for Ford". They apparently really went out of their way to make it difficult to change the idle mixture, and I think the plug is actually hardened steel too!
[Re: DrCharles]
#3146585
05/24/23 12:11 PM
05/24/23 12:11 PM
Posts: 15,357 Omaha Ne
TJP
Omaha Ne
This carb originally came off a '86 or '87 Ford truck, with either a 351W or 460. The primary bowl actually has cast into it, "Manufactured by Holley for Ford". They apparently really went out of their way to make it difficult to change the idle mixture, and I think the plug is actually hardened steel too! AHH you left out the oddball carb part (ford application) I would follow some of the previous suggestions and offer a few more 1. if you can find an appropriate size bottoming tap, you may be able to thread the cup enough to "Pull it out" with nuts & spacers. 2. A left handed drill may work 3. Depending on the depthe of the cup, once a hole is in it you may be able to "Roll" it out like a freeze plug. 4. Heating the aluminum with a small butane micro torch and quickly goiing after the plug may work as aluminum expands fairly quickly. 5. carbide tipped cement bits work well on hardened steels and they are dirt cheap. I would STRONGLY recommend using a drill press or mill so you have better control over the feed. You do not want the drill to get pulled in to the adj. screw Again a few pic's would help keep us posted
[Re: TJP]
#3146630
05/24/23 02:36 PM
05/24/23 02:36 PM
DrCharles
West Plains, MO
Thanks for the suggestions. I should buy a set of left-handed drill bits someday. I got them out, but not without a struggle. Tamper-proof, my ass First I tried to get a 1/16" welding rod to stick (usually the opposite of what I'm trying to do!), but ended up gouging a small pit in the plug instead. It had gotten hot enough that the temper was gone and I could drill into it with a #36 (picked that size in case I had to tap for a screw thread) deep enough for an easy-out. For once, an easy-out actually worked. Turns out they aren't welch plugs but a piece of solid steel rod about 1/4" deep. Now I'm going to cut a small screwdriver slot in the heads of the needles with a Dremel cutoff wheel so I don't have to use an Allen wrench and hope it doesn't strip out. Then it all goes back together. Here's the "before" picture of one of them for TJP (The secondaries have the bosses also, but they're not drilled. Just a "dribble hole" in the venturi).
[Re: DrCharles]
#3146701
05/24/23 10:21 PM
05/24/23 10:21 PM
TJP
Omaha Ne
Thanks for the suggestions. I should buy a set of left-handed drill bits someday. I got them out , but not without a struggle. Tamper-proof, my ass First I tried to get a 1/16" welding rod to stick (usually the opposite of what I'm trying to do!) , but ended up gouging a small pit in the plug instead. It had gotten hot enough that the temper was gone and I could drill into it with a #36 (picked that size in case I had to tap for a screw thread) deep enough for an easy-out. For once, an easy-out actually worked. Turns out they aren't welch plugs but a piece of solid steel rod about 1/4" deep. Now I'm going to cut a small screwdriver slot in the heads of the needles with a Dremel cutoff wheel so I don't have to use an Allen wrench and hope it doesn't strip out. Then it all goes back together. Here's the "before" picture of one of them for TJP (The secondaries have the bosses also, but they're not drilled. Just a "dribble hole" in the venturi).
[Re: 360view]
#3146943
05/26/23 02:32 PM
05/26/23 02:32 PM
Posts: 19,405 north of coder
moparx
Cheap brittle taps and drill bits have greatly stimulated my creativity to invent new curse words that reminds me of my old man............. one day, way many moons ago, he was doing some repair work at the Eagles Club here on main st. [he was a trustee for very long time before he passed]. he needed a 1/4" drill bit, and although the house was only a tick over a mile away, he didn't want to drive home for one. as there was a G.C. Murphy 5 & 10 cent store right across the street from the Club, and there were a few patrons "holding down the bar" [as the old man would say] he sent one of the most trusted [?] patrons across the street to get a 1/4" drill bit. since Murphy's didn't sell bits separately, a "complete quality set" was purchased for the princely sum [at the time] of $4.99 [plus tax of course]......... the old man grabbed the 1/4" bit, stuck it in the drill, and proceeded to drill the hole. when the hole broke through, it promptly bent into a 90 degree angle without breaking, causing the drill to be whipped from the old man's hands. the bar patrons ROARED with laughter, causing the old man to say lots of "bad words" ! then there was the time my brother was installing a metal stair railing in a loft apartment........ the railing was just your cheap-o home improvement store pre-made chinesium, painted black with the twisted uprights, needing holes drilled in the base[es] to mount to your stair treads. the chinesium drilled easily until the last hole. that one seemed tougher than the others, and looking at the bit, little bro saw it was getting a tad dull. he figured since it was the last hole, no big deal, since the chinesium must have been really tough on the bit, he would just finish the hole and toss the bit............ heaving on the drill until it started to slightly get "real warm", he FINALLY got the hole through !!!!!!! looking at the bit, he was surprised to find the tip of the bit BLUE ! well, the hole was through, and he was gonna toss the bit anyway. firing up the drill to cool it off, he found.............the drill was in REVERSE ! .............boy, did we howl when he told that story !
