How many jets are in a holly 750 DP? #314640
05/11/09 01:16 PM
05/11/09 01:16 PM
Murrayville, Illinois, usa
scotts66charger Offline OP
I am ready to pull the Holley 750 DP apart, and change the jet size(as per your recomendations here). My question is, how many jets are there? Are there 2 in front and 2 in the rear bowl, or just in the front Bowl? Thanx. scott
Re: How many jets are in a holly 750 DP? [Re: scotts66charger] #314641
05/11/09 01:23 PM
05/11/09 01:23 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
two in front...and two in rear.
Tony
70 AARCuda Vitamin C
Re: How many jets are in a holly 750 DP? [Re: 70AARcuda] #314642
05/12/09 09:15 AM
05/12/09 09:15 AM
I have changed the jets to a smaller size. I went down 6 sizes, but now it seems that its starving for gas, and runs worse than it did with the bigger jets.. To small now huh? I had 73 in front and 79 in the rear. Now i have 67 in front and 73 in the rear. What do you think about going back 3 sizes both ways and trying that?
Re: How many jets are in a holly 750 DP? [Re: scotts66charger] #314643
05/12/09 09:49 AM
05/12/09 09:49 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what's the application? I ran 74-80's in a mild 340 w/ 28 squirters and it ran good. 78-84's in a mild 440 w/ 31 squirters.
Re: How many jets are in a holly 750 DP? [Re: Mr.Yuck] #314644
05/12/09 09:52 AM
05/12/09 09:52 AM
too lean will also destroy the rings quicker as my uncle just found out in a 302 he just finished building.
Re: How many jets are in a holly 750 DP? [Re: scotts66charger] #314645
05/12/09 09:53 AM
05/12/09 09:53 AM
6 #'s is alot of change. Splitting the difference(3 sizes)sounds like a practical plan to start with
Re: How many jets are in a holly 750 DP? [Re: RapidRobert] #314646
05/12/09 09:55 AM
05/12/09 09:55 AM
ok, thanx guys. I will go change them out now, and get back to ya..
Re: How many jets are in a holly 750 DP? [Re: Mr.Yuck] #314647
05/12/09 10:08 AM
05/12/09 10:08 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I am a novice tuner, but I have some holley experience. Jumping one jet size is not enough to feel but six is kind of extreme. I think three steps at a time is good until you get close. Do you know how to read plugs?
You should have new plugs after your jet change. To check the primary jets turn the car off at cruise and coast to a good spot. Pull a plug and check the color. You want it to be cleanish with some brown tan color. Other colors can be from chemicals in the fuel. Fluffy black is rich a/f oily black is rings or valve seals leaking, look with a loupe or small magnifying glass on the ceramic for tiny metal balls- these would mean it's knocking (pinging, detonation etc.) I like to start rich and go down in jet sizes until it just starts to have a little surging while cruising under load, then go up one or two sizes.
Remember, if you floor it the secondaries come into play- that would effect the readings.
good luck
