Exhaust Manifold Studs #3146252
05/22/23 07:47 PM
05/22/23 07:47 PM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
So what do you use to stop the studs from leaking coolant ?
This is my 340 T/A engine with the stock cast iron T/A heads. Thanks , Kevin
Re: Exhaust Manifold Studs [Re: B5TA] #3146265
05/22/23 08:32 PM
05/22/23 08:32 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
permatex #2 on the threads that screw into the head.
Re: Exhaust Manifold Studs [Re: B5TA] #3146285
05/22/23 10:29 PM
05/22/23 10:29 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Any thread sealant should work. twocents
Re: Exhaust Manifold Studs [Re: TJP] #3146309
05/23/23 01:57 AM
05/23/23 01:57 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Should be a high temp version.
Re: Exhaust Manifold Studs [Re: PhillyRag] #3146329
05/23/23 08:13 AM
05/23/23 08:13 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Had a small leak on my 340 after installing new studs . Mine sealed up on their own after a few heat cycles.
Re: Exhaust Manifold Studs [Re: B5TA] #3146379
05/23/23 12:40 PM
05/23/23 12:40 PM
IL
8
83hurstguy Offline
83hurstguy  Offline
IL
I had a set with three studs that kept seeping until I used red high-temp RTV on the threads and in the hole. I used a rubber coupler with air chuck and regulated compressed air down to 10 psi so I could soap test the studs.
Re: Exhaust Manifold Studs [Re: mopars4ever] #3146508
05/24/23 12:15 AM
05/24/23 12:15 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Just like exhaust pipe joints, will tend to seal themselves from rusting, unless it's more then seepage.
Re: Exhaust Manifold Studs [Re: B5TA] #3146518
05/24/23 01:26 AM
05/24/23 01:26 AM
One small package of Alumimseal, I'll try and post a picture of one of them tomorrow luck
