Page 1 of 3 1 2 3
What do I do with this???? clogged head? carbon? #314595
05/11/09 01:14 PM
05/11/09 01:14 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
OK, as I always say, I am no mechanic. I love the body and paint work but hate mechanics. I am restoring this 67 power wagon and am changing the the 2BBl for a 4 BBL intake, new barn and electronic ignition.
when I pulled the 2BBL intake I found this clogged
port???? Ywo questions?
Can I just break it out and if so, how do I keep the mess from going inside the engine and causing issues.
And, what causes this, should I check further into the motor or do I need to fix something while I am in there?????
Its only clogged on one side.
Re: What do I do with this???? clogged head? carbon? [Re: RUMBLON] #314596
05/11/09 01:17 PM
05/11/09 01:17 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
thats the exhaust cross over
5549 post on old board
Re: What do I do with this???? clogged head? carbon? [Re: 05dakota] #314597
05/11/09 01:19 PM
05/11/09 01:19 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Ok, does that mean that I can simply break it inwards and it will be blown out the tail pipe? and any idea if something wrong is causing it, or is it normal??
Thanks Dave
Re: What do I do with this???? clogged head? carbon? [Re: RUMBLON] #314598
05/11/09 01:29 PM
05/11/09 01:29 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It's caused by burning oil and age. You can break it out, but I'd pull the rockers and pushrods and lay some paper in teh valley there to catch most of the pieces. OR, just don't worry about and know that the heat crossover will not work, making cold morning starts a little more difficult.
Re: What do I do with this???? clogged head? carbon? [Re: Jim_Lusk] #314599
05/11/09 01:35 PM
05/11/09 01:35 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Stab at it with a shop vac nozzle nearby.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: What do I do with this???? clogged head? carbon? [Re: Jim_Lusk] #314600
05/11/09 01:40 PM
05/11/09 01:40 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Thanks, Dave. I really appreciate the advise. I need to get this portion done and get back to the bed body work, the stuff I know and understand.
thanks again
Re: What do I do with this???? clogged head? carbon? [Re: CJK440] #314601
05/11/09 01:53 PM
05/11/09 01:53 PM
NE Ohio
71 FJ6 Charger Offline
NE Ohio
'71 383HP FJ6 Charger SE
Re: What do I do with this???? clogged head? carbon? [Re: 71 FJ6 Charger] #314602
05/11/09 02:08 PM
05/11/09 02:08 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
I had to drill it out Its approx 70 percent open at this point. Made sure nothing got into the valley and used the vacume anyways.
all I need now in the intake gaskets, valve cover gaskets, new fuel pump and thermostat and its mostly ready to go.
Now, I just need to repair the radiator support and install and I can get these painted fenders off of the ground
Lots of days work left.
thanks
Re: What do I do with this???? clogged head? carbon? [Re: RUMBLON] #314603
05/11/09 02:29 PM
05/11/09 02:29 PM
NY usa
540challenger Offline
NY usa
thanks
What 4BBl manifold are you putting on there alot of the aftermarket intake's don't used the crossover
Re: What do I do with this???? clogged head? carbon? [Re: RUMBLON] #314604
05/11/09 02:31 PM
05/11/09 02:31 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
As mentioned, the easiest way to clean it is with a shopvac nozzle sucking the particles up as you go.
The heat crossover heats the manifold so that the divorced choke will operate properly (in concert with the heat riser in the exhaust manifold) and it also helps keep the carb warm to atomize fuel better.
From my experience, even if the engine will start/run with a blocked crossover, you’re still losing MPG and washing your cylinders with fuel due to a choke that might not open fully. The effects of this vary with the climate you live in.
It’s also been my experience that this is a smallblock issue. I’ve had two 318s do this to me (one did it twice) but I’ve not yet had (or seen) a bigblock plug this passage.
Blocking/not blocking the crossover can be a heated discussion (pun intended) but IMO the closer to stock the engine is, the better off you are to maintain its function.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: What do I do with this???? clogged head? carbon? [Re: 540challenger] #314605
05/11/09 04:31 PM
05/11/09 04:31 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
thanks
this stock one but not the carb.
Re: What do I do with this???? clogged head? carbon? [Re: RUMBLON] #314606
05/11/09 04:41 PM
05/11/09 04:41 PM
I would not chip away anything out of there & risk a hardened piece of carbon getting by you & into the oiling system and as said add an electric choke otherwise the choke wont open up near fast enough & the plugs will foul in short order plus the mileage/cyl wash.
Re: What do I do with this???? clogged head? carbon? [Re: RUMBLON] #314607
05/11/09 04:42 PM
05/11/09 04:42 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Be aware that some of that crud will end up in 2 cylinders, as the other end of that channel of carbon is right at the exhaust bowls of the 2 cylinders. It will probably burn out of there anyway though, so just get as much out of there as you can. And the heat riser is probably no good, that's what makes that stuff pile up in there. The chevies also had the same problem and delayed choke opening etc.
Re: What do I do with this???? clogged head? carbon? [Re: buildanother] #314608
05/12/09 09:45 AM
05/12/09 09:45 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
This happened on my original 360 2bbl in my van. In 20 degree weather it would sputter when going slow around corners.
You need to pull the head IMO. Valve seals are probably shot. The valves are probably crudded up bad. Worn valve guides are often the reason.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: What do I do with this???? clogged head? carbon? [Re: Rug_Trucker] #314609
05/12/09 09:51 AM
05/12/09 09:51 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Like said above most of your after market performance manifolds are blocked any way so it would be of no advantage to go through the work to chip it out and risk getting carbon spread through the engine. See if your intake has open ports that match these before attempting to clean it. If not leave it alone.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: What do I do with this???? clogged head? carbon? [Re: buildanother] #314610
05/12/09 10:27 AM
05/12/09 10:27 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
make sure the exhaust valve is closed for those cylinders (i believe they are 5 and 4. if not its 3 and 6. look at the hump in the cylinder and it will go to an exhaust port) or else hard carbon will slip past the exhaust valve and into the cylinder
Re: What do I do with this???? clogged head? carbon? [Re: MoparforLife] #314611
05/12/09 10:58 AM
05/12/09 10:58 AM
Rug_Trucker Offline
Rug_Trucker  Offline
Not so! My holley SD, Eddie LD340, LD4B, Offy etc have exhaust crossovers. Your Crosswind, Airgap etc. don't. We are talking about a truck here, not a racecar.
I run with mine blocked off on my 360. It is an aluminum intake. It is OK even down to 2* But that is aluminum! Not iron! Gonna drive in the winter up there in Idaho, and Northern Nevada with an iron intake? Do the job right.
Re: What do I do with this???? clogged head? carbon? [Re: Rug_Trucker] #314612
05/12/09 11:16 AM
05/12/09 11:16 AM
Florida STAYcation
dOc … Online penguin-006
The village idiot's idiot
dOc …  Online Penguin-006
Florida STAYcation
I have not done a whole lot of A engine work .. but I have done this "deal" a couple of times.
What causes this is a mal-adjusted choke ...and that is just pure carbon. This situation ONLY happens on the iron 2 bbl intakes ...from what I have seen and heard.
If this is a streeter application and you care about fuel-econ ....you do NOT want to leave the head plugged-up.
As was suggested above .... use a shop vac. But this is a two-man-job ... one holding the shop vac as close to the crossover as possible while the other guy uses a slow die-grinder(or a fast drill) ...with a carbide burr on it.
Using a OEM choke should not be a prob with an alum intake since the choke will pull-off quicker since the intake heats-up LOTS quicker.
Cleaning-out those stock 2 bbl intakes ? ... I have heard that those require sometimes a full-WEEK in a hot-tank !
Re: What do I do with this???? clogged head? carbon? [Re: Rug_Trucker] #314613
05/12/09 11:55 AM
05/12/09 11:55 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Man, I didnt want to get into this engine that much. as stated above I drilled MOST of it out. The inside looks good, but I am no mechanic. So I should pull the heads and look at the valves seals. So, you mean it needs a valve job????
Re: What do I do with this???? clogged head? carbon? [Re: RUMBLON] #314614
05/12/09 12:03 PM
05/12/09 12:03 PM
Rug_Trucker Offline
Rug_Trucker  Offline
It might. I pulled a slant head apart that had crud caked up on the valves from the guides and seals leaking. Just one side of the head and stem.
A wire wheel fixed that. The faces of the valves were fine. It was a wonder it could breath with tha much crap on them.
Page 1 of 3 1 2 3
