Borgeson box - pitman arm nut torque #3145233
05/17/23 10:15 PM
05/17/23 10:15 PM
Windsor, ON, Canada
Diplomat360 Offline OP
Windsor, ON, Canada
1980 Dodge Diplomat coupe here...the FSM calls for 175 ft-lbs, but the Borgeson box instructions only call for 100-120 ft-lbs...seems like a big difference, no?
I compared the old nut to the new one and the threads in the nut, as in TPI, seemed identical, so why the big difference?
For what it's worth: I put 100 ft-lbs on there right now and the rubber seal that sits between the box body and pitman arm isn't compressed yet and shows space....so it would seem like the pitman arm should still "climb" the output shaft a bit more, and that'll need more torque on the nut.
I applied anti seize to both the pitman arm splines and the box output shaft splines to make the mating go easier. The same was applied on the nut and the lock washer, so it's not like I might be seeing weird torque readings because of friction alone.
Thanks!
Re: Borgeson box - pitman arm nut torque [Re: Diplomat360] #3145350
05/18/23 02:32 PM
05/18/23 02:32 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Has to be a difference in torque rating between the large and small sector shaft boxes. Anyone know what that is?
Re: Borgeson box - pitman arm nut torque [Re: MarkZ] #3145353
05/18/23 03:01 PM
05/18/23 03:01 PM
BDW Offline
BDW  Offline
No idea what the spec is, I had to use a 3ft cheater pipe to get the arm high enough up on the shaft so at least a thread was showing past the nut.
Read others having issues getting the arm up on the Borg shaft.
Re: Borgeson box - pitman arm nut torque [Re: BDW] #3145435
05/18/23 09:50 PM
05/18/23 09:50 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Not the first issue I've heard of or experienced with Borgy conversions down
Re: Borgeson box - pitman arm nut torque [Re: TJP] #3145441
05/18/23 10:06 PM
05/18/23 10:06 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Unless Borgeson told you to use antisieze on the threads their torque recommendation is moot.
The use of and type of lubricant used can have a profound effect on torque readings.
If Borgeson did specify antisieze that can account for the difference between their recommendation and what the FSM calls for.
A look at a generic torque specification chart may shed some light on this.
Here's what Antisieze has to say about it
https://www.antiseize.com/PDFs/torque_specifications.pdf
Re: Borgeson box - pitman arm nut torque [Re: Diplomat360] #3145655
05/19/23 08:06 PM
05/19/23 08:06 PM
Windsor, ON, Canada
Windsor, ON, Canada
Appreciate all the comments and feedback you guys.
I reached out to Brian @Borgeson this morning and asked him for advice / direction re: proper approach to this.
His response is as follows:
Quote
...The tapered length of the pitman shaft on the factory gearbox vs our new design gearbox may be different resulting in the differences in torque specs to seat the pitman arm completely on the pitman shaft. The gap between the pitman arm and the dust boot is not unusual as the pitman arm will only travel so far until it seats on the taper pitman shaft...You can go ahead and use 20 more ft lbs. than the 100-120 listed in the instructions but I would not exceed 140 ft lbs...
Obviously, I am NOT sharing this as applicable to all similar inquiries, however this was his response to mine.
Re: Borgeson box - pitman arm nut torque [Re: Diplomat360] #3145675
05/19/23 09:51 PM
05/19/23 09:51 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Quote
Sounds like their typical 💩 response. Why don't they jus fix the _____ing problem. I'm surprised you didn't get the "You're the only one that's had the issue" I'll give menial credit for that. Borgeson is not the company they used to be. Good enough is now adequate. RANT OFF flame
Re: Borgeson box - pitman arm nut torque [Re: TJP] #3145793
05/20/23 02:08 PM
05/20/23 02:08 PM
moparx Offline
moparx  Offline
well, a guy could always "tighten it up until it strips or breaks, then back it off 1/2 a turn"............ biggrin
beer
Re: Borgeson box - pitman arm nut torque [Re: moparx] #3145967
05/21/23 09:59 AM
05/21/23 09:59 AM
Windsor, ON, Canada
Windsor, ON, Canada
I went up to 140 ft-lbs, felt pretty solid, gave me a single thread showing past the nut and literally ended pushing the pitman arm up the shaft to exactly (+/- 0.050") the same place as where it was resting on the factory box. So I called it "quits" at that time!
The rest of the suspension pieces (so the tie-rods and steering linkage) are now all connected back up as well. That part of the project is done and that frees me up to finish the motor.
Thank you for the feedback everyone!
Re: Borgeson box - pitman arm nut torque [Re: Diplomat360] #3146091
05/21/23 10:43 PM
05/21/23 10:43 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up Surprised they didn't send you a thinner nut ozbbq laugh2
Re: Borgeson box - pitman arm nut torque [Re: Diplomat360] #3146190
05/22/23 02:12 PM
05/22/23 02:12 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Diplomat -- Could you tell IF the cross-link attachment point with the Pitman arm was now changed.... lower or higher... possibly causing an interference with the your exhaust/headers? If higher, then there would be a greater chance of interference; If lower, then there would be slightly more clearance away from the exhaust/headers.
I often wonder about the Borgenson ps box... with that described matter of linkage attachment and the results afterwards.
Re: Borgeson box - pitman arm nut torque [Re: Mopar Mitch] #3146901
05/26/23 10:56 AM
05/26/23 10:56 AM
Windsor, ON, Canada
Windsor, ON, Canada
Mopar Mitch:
Sorry about the delay in my response!
So the short answer is: NO, and that's because everything has been completely OUT of the engine bay for over a year now. So I literally have no point of reference at the moment, and the only option I would have had before I pulled the stock box out was to measure from the floor to 'somewhere'.
I'll be popping out to the garage this afternoon so let me compare the OEM vs Borgeson box and see if I can somehow get you the measurement you are looking for.
I was not concerned about this because my W2 build required me to move to a different set of headers, and those are the TTI pipes which do not go under the centerlink (where it's usually the tightest fit).
