1965 Coronet window channel
#3144938
05/16/23 10:37 AM
05/16/23 10:37 AM
Posts: 1,487 STL
cdstl
STL
Guys, I'm looking for the "run channel" that the forward edge of the door glass runs in. I've found some from Van's but it doesn't say that it's for my car. What's your opinion on using these fuzzies in my car? https://vansauto.com/product/mopar-...door-glass-window-channel-run-pn2932230/Thanks
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: 1965 Coronet window channel
[Re: moparx]
#3145039
05/16/23 09:19 PM
05/16/23 09:19 PM
Posts: 1,487 STL
cdstl
STL
I could probably have them measure it. The thing is that they fit the 65-68 C bodies as well, that's what has me thinking.
[Re: poorboy]
#3145106
05/17/23 10:33 AM
05/17/23 10:33 AM
Posts: 307 Georgia
69bfan
Georgia
The mylar glass channel runs as pictured by the OP will not work for the 62 to 65 B-Body applications. The mylar runs were used from 1966 up through 1993 on a wide variety of applications. The mylar channels actually attaches to the door glass and moves within the division bar as the glass goes up and down. For the 62 to 65 applications, you will need a glass channel run that is similar to a velcro type of material that is glued to the division bar. Some of the glass shops may sell it under the mohair listing. It comes in a variety of width and thickness and you just purchase the desired length. Relatively inexpensive. A good glass shop or restoration supplier will stock the material.
www.restorationpartsandmaterials.comCorrect Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs. www.dalescudashop.comCorrect style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
[Re: 69bfan]
#3145115
05/17/23 11:45 AM
05/17/23 11:45 AM
Posts: 1,487 STL
cdstl
STL
Thanks for the information.
