1965 Coronet window channel #3144938
05/16/23 10:37 AM
05/16/23 10:37 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Guys,
I'm looking for the "run channel" that the forward edge of the door glass runs in. I've found some from Van's but it doesn't say that it's for my car. What's your opinion on using these fuzzies in my car?
https://vansauto.com/product/mopar-...door-glass-window-channel-run-pn2932230/
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: 1965 Coronet window channel [Re: cdstl] #3144997
05/16/23 02:49 PM
05/16/23 02:49 PM
moparx Online content
moparx  Online Content
i'm thinking the 65's have more in common with the 64's than the 66's, but as long as those are the right width to fit into your channel and are long enough, [or can be cut to length] they "should" work.
have you thought about contacting van's to see if they could provide you with measurements ?
beer
Re: 1965 Coronet window channel [Re: moparx] #3145039
05/16/23 09:19 PM
05/16/23 09:19 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I could probably have them measure it. The thing is that they fit the 65-68 C bodies as well, that's what has me thinking.
Re: 1965 Coronet window channel [Re: cdstl] #3145044
05/16/23 09:55 PM
05/16/23 09:55 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Usually the glass thickness and the in door channel width changes. Measure the glass thickness (often new glass is thinner then the original glass was) and the outside width of piece the channel fits into that you have and contact the seller. The channel material is usually sold in bulk, and several auto manufactures uses the 3 or 4 specific sizes. I'd be amazed if the seller of your choice couldn't get the replacement channels you need.
Re: 1965 Coronet window channel [Re: poorboy] #3145106
05/17/23 10:33 AM
05/17/23 10:33 AM
Georgia
69bfan Offline
69bfan  Offline
Georgia
The mylar glass channel runs as pictured by the OP will not work for the 62 to 65 B-Body applications. The mylar runs were used from 1966 up through 1993 on a wide variety of applications. The mylar channels actually attaches to the door glass and moves within the division bar as the glass goes up and down. For the 62 to 65 applications, you will need a glass channel run that is similar to a velcro type of material that is glued to the division bar. Some of the glass shops may sell it under the mohair listing. It comes in a variety of width and thickness and you just purchase the desired length. Relatively inexpensive. A good glass shop or restoration supplier will stock the material.
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
Re: 1965 Coronet window channel [Re: 69bfan] #3145115
05/17/23 11:45 AM
05/17/23 11:45 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Thanks for the information.
Re: 1965 Coronet window channel [Re: cdstl] #3145403
05/18/23 08:23 PM
05/18/23 08:23 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
69Bfan is correct...
...FAFO...
