Re: Corvette suspension on old mopars.
[Re: migsBIG]
#3145010
05/16/23 05:51 PM
05/16/23 05:51 PM
Posts: 3,459 Dandridge TN
Dabee
Dandridge TN
I used Speedway Motors G/Comp front suspension on my last build. Uses Corvette front brakes. I built the chassis and used triangular four link with coil over shocks in the rear. Something to think about. Photo didn’t attach on first try
[Re: Dabee]
#3145012
05/16/23 05:55 PM
05/16/23 05:55 PM
Dabee
Dandridge TN
This chassis went under a 1948 Federal Motors Truck.
[Re: moparx]
#3148351
06/03/23 06:38 AM
06/03/23 06:38 AM
Posts: 21,674 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
[Re: migsBIG]
#3149258
06/06/23 11:34 PM
06/06/23 11:34 PM
Posts: 4,757 Moved to N.E. Tennessee
GomangoCuda
To be honest, I’m thinking the 41’ Plymouth is going to be my next project when my Cuda and Charger is finished. I was thinking some of the gen 4/5/6 corvette suspension and brakes offer in kits would be good swap onto the car. Was wondering if anyone has done that with their car. Sun frame clips were all the rage with camaro/nova/Firebird/corvair 30+ years ago, but the thought of better suspension options, upgrades and even brakes makes it really tempting. Post what you know. I wonder if it would be possible adapt the entire vette frame and suspension to the 41.
[Re: GomangoCuda]
#3149864
06/08/23 10:59 PM
06/08/23 10:59 PM
Posts: 10,631 Freeport IL USA
poorboy
Freeport IL USA
To be honest, I’m thinking the 41’ Plymouth is going to be my next project when my Cuda and Charger is finished. I was thinking some of the gen 4/5/6 corvette suspension and brakes offer in kits would be good swap onto the car. Was wondering if anyone has done that with their car. Sun frame clips were all the rage with camaro/nova/Firebird/corvair 30+ years ago, but the thought of better suspension options, upgrades and even brakes makes it really tempting. Post what you know. I wonder if it would be possible adapt the entire vette frame and suspension to the 41. I'm thinking the Corvette frame is going to be pretty short for the 41 Plymouth and suspension is probably going to be too wide. The short frame isn't too hard to overcome, but too wide causes a lot of problems. That 41 Plymouth has pretty close to a 60" wheel mounting surface width, I suspect the Vette is several inches wider.
[Re: poorboy]
#3150030
06/09/23 02:52 PM
06/09/23 02:52 PM
Posts: 6,306 nowhere
Sniper
nowhere
To be honest, I’m thinking the 41’ Plymouth is going to be my next project when my Cuda and Charger is finished. I was thinking some of the gen 4/5/6 corvette suspension and brakes offer in kits would be good swap onto the car. Was wondering if anyone has done that with their car. Sun frame clips were all the rage with camaro/nova/Firebird/corvair 30+ years ago, but the thought of better suspension options, upgrades and even brakes makes it really tempting. Post what you know. I wonder if it would be possible adapt the entire vette frame and suspension to the 41. I'm thinking the Corvette frame is going to be pretty short for the 41 Plymouth and suspension is probably going to be too wide. The short frame isn't too hard to overcome, but too wide causes a lot of problems. That 41 Plymouth has pretty close to a 60" wheel mounting surface width, I suspect the Vette is several inches wider. Wide body 41 Plymouth?
[Re: Sniper]
#3150042
06/09/23 03:31 PM
06/09/23 03:31 PM
poorboy
Freeport IL USA
To be honest, I’m thinking the 41’ Plymouth is going to be my next project when my Cuda and Charger is finished. I was thinking some of the gen 4/5/6 corvette suspension and brakes offer in kits would be good swap onto the car. Was wondering if anyone has done that with their car. Sun frame clips were all the rage with camaro/nova/Firebird/corvair 30+ years ago, but the thought of better suspension options, upgrades and even brakes makes it really tempting. Post what you know. I wonder if it would be possible adapt the entire vette frame and suspension to the 41. I'm thinking the Corvette frame is going to be pretty short for the 41 Plymouth and suspension is probably going to be too wide. The short frame isn't too hard to overcome, but too wide causes a lot of problems. That 41 Plymouth has pretty close to a 60" wheel mounting surface width, I suspect the Vette is several inches wider. Wide body 41 Plymouth? I guess if that is what the owner wants, I say he should go for it.
[Re: migsBIG]
#3153683
06/22/23 09:28 PM
06/22/23 09:28 PM
Sniper
nowhere
No, not what I want. If you were to read the article, the cradle can be narrowed to the same width as the Plymouth. My concern is mainly on how to mount it properly so it works as intended.
Your 41's frame is similar to my 51 Plymouth's. Anything can be made to fit, but you are going to be removing the welded in front cross member and probably have to flatten and raise the front rails.
[Re: Sniper]
#3153692
06/22/23 10:13 PM
06/22/23 10:13 PM
poorboy
Freeport IL USA
Yep, its a cut and weld process. You cut off what you don't need, and weld on the new stuff.
I didn't read the article, and don't intend to, there is nothing about a Vette that interests me.I would probably go towards a modern Charger suspension over a Vette anything.
Straight and true are always the 1st concerns. Finished ride height is the next challenge. The Plymouth frame sits up pretty high off the ground, the Corvette frame sits a lot lower then the Vette frame, you may end up placing the Plymouth frame on top of the Vette frame to get a serviceable driver, but if you are using both the front and the rear Vette frame sections that support the Vette suspension, you may be better off the just extend the length of the Vette frame. Then all you need to be concerned about would be how to attach the Plymouth to the Vette frame. They are very different.
[Re: Sniper]
#3153849
06/23/23 02:40 PM
06/23/23 02:40 PM
poorboy
Freeport IL USA
Its still a Vette system (or pretends to be), one of 3 or 4 different versions, none of which impress me enough to install under a different vehicle. I would probably be way less impressed with a system that has been narrowed to "fit" more vehicles .I've seen enough poorly designed "kits" to not have a desire to look at another one, let alone do the work required to make most of these "kits" function.
I've modified frames and bolted the old Mopar cross torsion bar cradle onto different vehicles back when that was the thing to do, as well as more then a few other specially built cradles that were suppose to bolt onto your existing frame. In most cases, you cut off the existing front (or rear) frame, and build something to hold the cradle.
The OP asked what we knew. I've responded. I've actually done this stuff with vehicles that have actually been driven, and have been called in to help several get a "kit" to go down the road safely.
Its a lot of work for the small amount of improvement you probably wouldn't notice, unless your taking up road racing or parking lot timed events. For something street driven, those fancy sub frames only add to the cost for very little (if any) noticeable improvement.
