Corvette suspension on old mopars. #3144848
05/15/23 10:40 PM
05/15/23 10:40 PM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
To be honest, I’m thinking the 41’ Plymouth is going to be my next project when my Cuda and Charger is finished. I was thinking some of the gen 4/5/6 corvette suspension and brakes offer in kits would be good swap onto the car. Was wondering if anyone has done that with their car. Sun frame clips were all the rage with camaro/nova/Firebird/corvair 30+ years ago, but the thought of better suspension options, upgrades and even brakes makes it really tempting. Post what you know.
Re: Corvette suspension on old mopars. [Re: migsBIG] #3144988
05/16/23 02:11 PM
05/16/23 02:11 PM
moparx Offline
moparx  Offline
as a thought, have you considered a complete chassis that utilizes the vette suspension[s] ?
i think Swartz [?] may be one company that does those.
beer
Re: Corvette suspension on old mopars. [Re: migsBIG] #3145010
05/16/23 05:51 PM
05/16/23 05:51 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I used Speedway Motors G/Comp front suspension on my last build. Uses Corvette front brakes. I built the chassis and used triangular four link with coil over shocks in the rear. Something to think about. Photo didn’t attach on first try
Re: Corvette suspension on old mopars. [Re: Dabee] #3145012
05/16/23 05:55 PM
05/16/23 05:55 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
This chassis went under a 1948 Federal Motors Truck.
Re: Corvette suspension on old mopars. [Re: Dabee] #3145139
05/17/23 01:39 PM
05/17/23 01:39 PM
moparx Offline
moparx  Offline
pictures or it didn't happen ! drool
beer
Re: Corvette suspension on old mopars. [Re: moparx] #3145179
05/17/23 05:28 PM
05/17/23 05:28 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Photos didn’t attach fist time the are there now. A couple from the rear.
Re: Corvette suspension on old mopars. [Re: Dabee] #3145181
05/17/23 05:34 PM
05/17/23 05:34 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Finished
Re: Corvette suspension on old mopars. [Re: Dabee] #3145192
05/17/23 07:33 PM
05/17/23 07:33 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
I have an article that has a bolt in kit for the vet parts, and they build to specs, which is a simpler way of doing it. I’ll post the link and article when I get home tonight.
Re: Corvette suspension on old mopars. [Re: Dabee] #3145575
05/19/23 01:35 PM
05/19/23 01:35 PM
moparx Offline
moparx  Offline
cool different truck you won't see every day ! up
beer
Re: Corvette suspension on old mopars. [Re: moparx] #3148351
06/03/23 06:38 AM
06/03/23 06:38 AM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Re: Corvette suspension on old mopars. [Re: migsBIG] #3149258
06/06/23 11:34 PM
06/06/23 11:34 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I wonder if it would be possible adapt the entire vette frame and suspension to the 41. work
Re: Corvette suspension on old mopars. [Re: GomangoCuda] #3149597
06/07/23 11:00 PM
06/07/23 11:00 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Someone with fabrication skill could do it, the kit just narrows a stock corvette cradle and adjustment points. If I was to call them and ask, they might have an answer.
Re: Corvette suspension on old mopars. [Re: GomangoCuda] #3149864
06/08/23 10:59 PM
06/08/23 10:59 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I'm thinking the Corvette frame is going to be pretty short for the 41 Plymouth and suspension is probably going to be too wide. The short frame isn't too hard to overcome, but too wide causes a lot of problems. That 41 Plymouth has pretty close to a 60" wheel mounting surface width, I suspect the Vette is several inches wider.
Re: Corvette suspension on old mopars. [Re: poorboy] #3150030
06/09/23 02:52 PM
06/09/23 02:52 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Wide body 41 Plymouth?
Re: Corvette suspension on old mopars. [Re: Sniper] #3150042
06/09/23 03:31 PM
06/09/23 03:31 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I guess if that is what the owner wants, I say he should go for it.
Re: Corvette suspension on old mopars. [Re: migsBIG] #3153670
06/22/23 08:47 PM
06/22/23 08:47 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
I'm thinking the Corvette frame is going to be pretty short for the 41 Plymouth and suspension is probably going to be too wide. The short frame isn't too hard to overcome, but too wide causes a lot of problems. That 41 Plymouth has pretty close to a 60" wheel mounting surface width, I suspect the Vette is several inches wider. [/quote]
Wide body 41 Plymouth? [/quote]
I guess if that is what the owner wants, I say he should go for it. [/quote]
No, not what I want. If you were to read the article, the cradle can be narrowed to the same width as the Plymouth. My concern is mainly on how to mount it properly so it works as intended.
Re: Corvette suspension on old mopars. [Re: migsBIG] #3153683
06/22/23 09:28 PM
06/22/23 09:28 PM
nowhere
nowhere
Your 41's frame is similar to my 51 Plymouth's.
Anything can be made to fit, but you are going to be removing the welded in front cross member and probably have to flatten and raise the front rails.
Re: Corvette suspension on old mopars. [Re: Sniper] #3153692
06/22/23 10:13 PM
06/22/23 10:13 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Yep, its a cut and weld process. You cut off what you don't need, and weld on the new stuff.
I didn't read the article, and don't intend to, there is nothing about a Vette that interests me.I would probably go towards a modern Charger suspension over a Vette anything.
Straight and true are always the 1st concerns. Finished ride height is the next challenge. The Plymouth frame sits up pretty high off the ground, the Corvette frame sits a lot lower then the Vette frame, you may end up placing the Plymouth frame on top of the Vette frame to get a serviceable driver, but if you are using both the front and the rear Vette frame sections that support the Vette suspension, you may be better off the just extend the length of the Vette frame. Then all you need to be concerned about would be how to attach the Plymouth to the Vette frame. They are very different.
Re: Corvette suspension on old mopars. [Re: poorboy] #3153831
06/23/23 01:24 PM
06/23/23 01:24 PM
nowhere
nowhere
You should have read the article.
It's essentially a cradle you'll bolt to the existing frame, suitably modified of course.
Re: Corvette suspension on old mopars. [Re: Sniper] #3153849
06/23/23 02:40 PM
06/23/23 02:40 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Its still a Vette system (or pretends to be), one of 3 or 4 different versions, none of which impress me enough to install under a different vehicle. I would probably be way less impressed with a system that has been narrowed to "fit" more vehicles .I've seen enough poorly designed "kits" to not have a desire to look at another one, let alone do the work required to make most of these "kits" function.
I've modified frames and bolted the old Mopar cross torsion bar cradle onto different vehicles back when that was the thing to do, as well as more then a few other specially built cradles that were suppose to bolt onto your existing frame. In most cases, you cut off the existing front (or rear) frame, and build something to hold the cradle.
The OP asked what we knew. I've responded. I've actually done this stuff with vehicles that have actually been driven, and have been called in to help several get a "kit" to go down the road safely.
Its a lot of work for the small amount of improvement you probably wouldn't notice, unless your taking up road racing or parking lot timed events. For something street driven, those fancy sub frames only add to the cost for very little (if any) noticeable improvement.
