Re: 727 shield?
[Re: J_BODY]
#3140987
04/27/23 10:41 AM
04/27/23 10:41 AM
Posts: 9,863 MI, usa
dvw
MI, usa
Blankets work well. But they are bulky and hold heat. They also can collect fluid if you have leaks. If it's a dedicated racecar the best thing I ever did was open up the tunnel for clearance. Then you can run an aluminum shield. It's not that hard to do. Doug
Re: 727 shield?
[Re: bobs69]
#3141059
04/27/23 05:49 PM
04/27/23 05:49 PM
Posts: 31,052 Oregon
AndyF
Just bought a 68 valiant with a big block with a 727. Will a transmission shield fit with a stock floor? Does any brand fit better than the others? Thanks No, shield will not fit a stock floor. You'll have to get under there with a hammer and move some metal around before a shield will fit. I tried to put a shield on the 727 under my Duster and finally gave up. It was a street car on street tires so I sold the shield to a racer and stopped beating on the floor.
Re: 727 shield?
[Re: bobs69]
#3141135
04/28/23 06:57 AM
04/28/23 06:57 AM
Posts: 2,931 A shed in England
Tig
A shed in England
I prefer a 1 piece shield rather than having to run a blanket and separate flex plate shield, almost always you have to modify the firewall / floor seam to get them to fit. I agree that a blanket would work better in the event of any explosive failure but I also try to minimise that risk as well. You can re-tag and re-cert a shield as long as they are in good condition and they are a lot easier to clean. If a blanket has any oil soak or contamination, it won't re-cert.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
