Fuel Tank Baffles
#3144044
05/11/23 10:39 PM
05/11/23 10:39 PM
Posts: 4,405 Michigan
MarkZ
Worthy
Worthy
I'm having a fuel tank custom built for the car and could use some opinions. Do you guys think the baffle in this would be sufficient? This is a 100% street car with a few trips down the track with a goal of an 11.9x timeslip. Car has a Holley Sniper which runs great, but I've always had a fuel starvation problem with the factory tank and external pump. Last time at the track it sucked air off of the launch. New tank will have the pump internal. Thanks guys.
Re: Fuel Tank Baffles
[Re: TJP]
#3144059
05/11/23 11:42 PM
05/11/23 11:42 PM
MarkZ
Worthy
Worthy
Where is the pickup going to be? Holley also sells product you might want to look into. pricey but ? HOLLEY HYDRAMAT Pickup is going towards to the top above the V baffle. I looked at the Hydromat including the Aeromotive retrofit pump with the sponge baffle, but decided on a custom tank in the end. The old tank was too wide to run 3" dual exhaust out to the bumper on either side. This new one is a couple inches narrower in dimension.
[Re: TJP]
#3144161
05/12/23 12:54 PM
05/12/23 12:54 PM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
Where is the pickup going to be? Holley also sells product you might want to look into. pricey but ? HOLLEY HYDRAMAT Some F.A.S.T. racers use this so they can run as little fuel as possible.
[Re: JohnRR]
#3144179
05/12/23 01:47 PM
05/12/23 01:47 PM
MarkZ
Worthy
Worthy
I'm thankful for opinions, but the advice is a bit more race oriented. I'm just looking for opinions on the internal baffle structure before the lid gets welded on. Car isn't a circle track runner or road course carver. Only track it'll see is the occasional quarter on test and tune nights. With the stock unbaffled tank it would suck air just pulling into a parking lot with a 1/4 tank of fuel.
[Re: Neil]
#3144266
05/12/23 09:28 PM
05/12/23 09:28 PM
Posts: 15,315 Omaha Ne
TJP
Omaha Ne
If I wanted to see how it would work I would get some clear sign acrylic and temporarily attach it to the top with some colored water in the tank. Slosh it around and see what you have going on. Good idea Neil, Myself I don't understand the concept of the V baffle. Yes it will slow the fuel down but not stop it from going to the opposite end of the tank. there are a lot of variables involved. I would think a partition with a series of holes (size to be determined) would be more effective. if the V were welded to the bottom of the tank it would also add strength when the tank is full. This is why you see most serious drag cars with a sump at the back ant the pickup on the bottom.
[Re: MarkZ]
#3144973
05/16/23 01:06 PM
05/16/23 01:06 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
You can run the stock tank or the one you are making with a surge tank set-up and you'd never get cavitation in your fuel system again.
The system would use Holley Hydromat with an in-tank pump that's connected to a surge tank with an equal sized return back to the tank. The fuel will then circulate at near zero psi, but at high volume. Alone you can still get cavitation as you have been experiencing it, but the air bubbles are quickly returned to the tank from the surge tank itself.
Your main fuel pump then goes into the bottom of the surge tank, up to the motor where it bypasses at the pressure regulator what is not used and sends it back to the surge tank.
This system eliminates virtually all air from the fuel system even when you are down to the last gallon of fuel. Works for EFI & carburated fuel systems. I run the low pressure side through two, high volume water traps/filters.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: MarkZ]
#3145081
05/17/23 07:34 AM
05/17/23 07:34 AM
JohnRR
U.S.S.A.
. With the stock unbaffled tank it would suck air just pulling into a parking lot with a 1/4 tank of fuel. Not with a hydramat.
[Re: MarkZ]
#3145132
05/17/23 01:07 PM
05/17/23 01:07 PM
TJP
Omaha Ne
With the stock unbaffled tank it would suck air just pulling into a parking lot with a 1/4 tank of fuel. Unless you were idling for an extended time on a relatively steep slope that is hard to understand. Can you explain a bit more? I would would say the location / height of the pickup was at fault. I know my Charger would suck air under 1/4 tank when romping on it hard but it wasn't immediate maybe top of 1st or midway through 2nd?
[Re: TJP]
#3145158
05/17/23 03:28 PM
05/17/23 03:28 PM
MarkZ
Worthy
Worthy
With the stock unbaffled tank it would suck air just pulling into a parking lot with a 1/4 tank of fuel. Unless you were idling for an extended time on a relatively steep slope that is hard to understand. Can you explain a bit more? I would would say the location / height of the pickup was at fault. I know my Charger would suck air under 1/4 tank when romping on it hard but it wasn't immediate maybe top of 1st or midway through 2nd? This is what I had cobbled together during the Sniper install. It's a really shallow tank. Under a 1/4 tank basic maneuvering in a parking lot or mild acceleration would cause it to suck air. I did make sure the new pickup could touch bottom. Honestly though, making the old tank work wasn't even in the cards. It's so wide the pinch seems interfered with the exhaust pipes as it wasn't designed for duals. The secondary goal of the new tank was to make room for 3" pipes on either side. Probably just going to have the fabricator finish it off with a circular baffle around the pump and call it good.
[Re: MarkZ]
#3145217
05/17/23 09:24 PM
05/17/23 09:24 PM
TJP
Omaha Ne
[Re: TJP]
#3147807
05/31/23 12:40 PM
05/31/23 12:40 PM
Posts: 2,814 Connecticut
FurryStump
Connecticut
Hydramat will solve any issues with sucking air. With baffles you won’t really know until it is together and hit it. I have absolute confidence in the hydramat. Even though you car isn’t a race car it is suffering from a race car issue. I went from having to run over 1/2 tank down to 2 gallons in a stock tank with hydramat. I can run so little fuel that I have pulled it into the trailer, left it in the trailer for a week and the fuel slowly drains out of the hydramat and it won’t start. Shake the car a bunch and slosh the fuel and it will fire right off.
[Re: TJP]
#3147811
05/31/23 12:51 PM
05/31/23 12:51 PM
FurryStump
Connecticut
With the stock unbaffled tank it would suck air just pulling into a parking lot with a 1/4 tank of fuel. Unless you were idling for an extended time on a relatively steep slope that is hard to understand. Can you explain a bit more? I would would say the location / height of the pickup was at fault. I know my Charger would suck air under 1/4 tank when romping on it hard but it wasn't immediate maybe top of 1st or midway through 2nd? Because it is fuel injected it will be very sensitive to fuel supply dips in pressure.
