7 blade clutch fan vs flex a lite
#3143906
05/11/23 12:51 PM
05/11/23 12:51 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
Has anyone done any testing on horsepower differences between these two fans? I have a 7 blade 18" clutch fan with a Jag clutch and an 18" Flex a Lite fan. I've used both with the same cooling results. Just wondering if there is any HP difference between the two?
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: 7 blade clutch fan vs flex a lite
[Re: 68LAR]
#3143930
05/11/23 01:57 PM
05/11/23 01:57 PM
Posts: 271 Anchorage, Alaska
metallicareload
Anchorage, Alaska
Engine Masters did a thing on this and flex fans were generally the worst by a good bit. I think the worst one was a plastic fan at full flaps
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: metallicareload]
#3143965
05/11/23 04:37 PM
05/11/23 04:37 PM
Posts: 8,166 Plymouth, MI
Blusmbl
Plymouth, MI
Engine Masters did a thing on this and flex fans were generally the worst by a good bit. I think the worst one was a plastic fan at full flaps x2. Best is obviously an electric fan. Next best is the clutch fan setup. The flex fans are worse for parasitic loss.
[Re: Blusmbl]
#3143973
05/11/23 05:41 PM
05/11/23 05:41 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Engine Masters did a thing on this and flex fans were generally the worst by a good bit. I think the worst one was a plastic fan at full flaps x2. Best is obviously an electric fan. Next best is the clutch fan setup. The flex fans are worse for parasitic loss. i had very good luck using a clutch seven blade fan on a 408. The clutch limits fan rpm, which limits power loss. Flex fans, not so much.
[Re: gregsdart]
#3143991
05/11/23 07:07 PM
05/11/23 07:07 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
Engine Masters did a thing on this and flex fans were generally the worst by a good bit. I think the worst one was a plastic fan at full flaps x2. Best is obviously an electric fan. Next best is the clutch fan setup. The flex fans are worse for parasitic loss. i had very good luck using a clutch seven blade fan on a 408. The clutch limits fan rpm, which limits power loss. Flex fans, not so much. How about a flex fan mounted on a clutch?
[Re: DrCharles]
#3144028
05/11/23 09:48 PM
05/11/23 09:48 PM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
Engine Masters did a thing on this and flex fans were generally the worst by a good bit. I think the worst one was a plastic fan at full flaps x2. Best is obviously an electric fan. Next best is the clutch fan setup. The flex fans are worse for parasitic loss. i had very good luck using a clutch seven blade fan on a 408. The clutch limits fan rpm, which limits power loss. Flex fans, not so much. How about a flex fan mounted on a clutch? Doubt you can find a flex fan that will fit on a clutch.
[Re: Moparite]
#3144420
05/13/23 04:43 PM
05/13/23 04:43 PM
DrCharles
West Plains, MO
That kind of defeats the purpose, The flex fan "flattens out" at high rpm's and the clutch limits the rpms of the fan. Electric fan is way to go, No drag on the engine. Where does the power to run the electric motor come from? From the alternator. What drives the alternator? A belt from the engine. Now when the fan is turned off, there's no power required. How much power does a mechanical fan consume when it's basically freewheeling?
[Re: DrCharles]
#3144615
05/14/23 09:23 PM
05/14/23 09:23 PM
gregsdart
Engine Masters did a thing on this and flex fans were generally the worst by a good bit. I think the worst one was a plastic fan at full flaps x2. Best is obviously an electric fan. Next best is the clutch fan setup. The flex fans are worse for parasitic loss. i had very good luck using a clutch seven blade fan on a 408. The clutch limits fan rpm, which limits power loss. Flex fans, not so much. How about a flex fan mounted on a clutch? The seven blade moves a ton of air at low speeds, making it efficient because max rpm it will see due to the clutch is tied to its huge capacity to move air.
