Re: BAM lifter mod
[Re: mopar dave]
#3036932
04/25/22 11:30 AM
04/25/22 11:30 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I realize the job is already done, but for anyone needing to do this in the future, I would suggest using a lathe to broach a scratch from hole to hole. Much more consistent/ controllable. Just lock the chuck, and turn the cutting bit 90°.
Re: BAM lifter mod
[Re: mopar dave]
#3143187
05/08/23 11:27 AM
05/08/23 11:27 AM
Posts: 9,949 Weddington, N.C.
Streetwize
Weddington, N.C.
Question, if you run a conventional Mopar solid or solid roller lifter with a hollow pushrod, will you still get any oil through the pushrods?
I've been fabricating bushing "sleeves" that i slip around the rocker hold down studs in the head where the oil channel passes up to the heads in order to reduce the amount of oil flow to the top as the stock system seems to push way too much oil up top that I'd rather have in the sump. I liken my simple mod to the guys back inthe day that use to machine the oil passages in the block to install holley fuel jets to reduce the volume,
I was always curious to know if any oil would reach the rocker through a hollow pushrod anyway. In either event it seems the rocker/pushrod ball/cup would get enough splash or vapor oiling in a conventional wet sump engine anyway. But with pushrod only (no shaft flow) oiling I could see that being a problem.
Re: BAM lifter mod
[Re: mopar dave]
#3143675
05/10/23 01:34 PM
05/10/23 01:34 PM
Posts: 182 Idaho
boomerodell
Idaho
Yes, it fixed the issue. I didn't make it out to the track last year and maybe a good thing as last time i spoke with Best machine, they said not to make a full pass, because these lifters require bushed lifter bores and it may suck the pan dry and kick a rod out. My 400 block is not bushed. I did run it hard down the freeway a few times last year without issue, but not like a full qrt pass. Thinking i may have to use these in the BMP Hemi block and get something else for my 511 stock block. Glad that lifter mod worked I have 2 sets of these lifters for upcoming builds and may come across this issue too. One is for a iron hemi and one for a wedge... Also 511 from stock 400. I'm trying to figure out this bushed lifter bore debate. Best told me the exact same thing when discussing my hemi combo, but how is a guy supposed to know unless it's too late? I've seen photos of hemi builds on Indy's FB some without bushed lifters in iron blocks with BAM lifters. They must be getting away with it?
