"at your own risk" is right
IMO,bad idea!
why,I did this on a truck when the pump let go,drove it for a while like that
"then one day" I stomped the brakes in a sand bed that I was going to make a left turn in..."to sink the tires some" so I could spin out turning....well lit up first,makeing the turn...banged 2nd gear,wot and closing on 5000 grand..when bam..I run over a good size rock with the front pass side tire...snatched the wheel from my hand and sprang about 4 fingers and hit a oak tree in 2nd at wot...shut it right off and totaled the truck....
armstrong does not cut it...IMO worse way to drive one,you may think you can hold it,but you cant,you dont realize just how hard the shock to the front wheels can be in a milla second,the tires can out leverage you holding the wheel
the manual gear box has a larger steering wheel and a better ratio for the leverage it takes to control the wheels
when a ps is bypased you have to move the fluild around both ways in the ps box itself, which can cause over steer and under steer real quik when "show boating"
not to mention all the stress on the colum,rag joint,ps box,tie rods,ect
that was a valuable lesson I learned doing it,I would not do it again and dont suggest it either,
4 spang fingers,busted lip,banged up knee,wrecked truck...decide for your self!
if you do...I am glad I live in FL.
good luck and be safe!
