Any idea what this weighs? #3143457
05/09/23 05:28 PM
05/09/23 05:28 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Seller can’t tell me if it’s a D400 or what. He thinks maybe 1 1/2 ton dump bed.
Trying to guess if my car trailer will handle it. It’s not a heavy duty one 🤣
Re: Any idea what this weighs? [Re: RUMBLON] #3143461
05/09/23 05:32 PM
05/09/23 05:32 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Ask these guys they would know.
Re: Any idea what this weighs? [Re: Sniper] #3143530
05/09/23 10:16 PM
05/09/23 10:16 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Are you getting the entire truck? Or just the sheet metal? If its complete, its heavy.
I'd rid it of the bed unless you really want it. Then maybe the outer duals unless you want them. Finding tires for those old wheels is getting tough (and expensive). Same with the motor/trans, unless it has an old Hemi, the flathead 6 itself weighs more then a a modern V8 auto trans (not the OD). Weight wise, once the bed, the drive train, and the outer duals are gone, it probably isn't real heavy, 5,000-6,000lbs. I would be concerned about the length, will the tires on both axles fit on your trailer's flat bed? Understand all the weight is going to be at both ends of your trailer. The rear end of cheap trailers is pretty weak, usually, and if that has a 2 speed rear end, its heavy.
Pic, I lifted this off the trailer with an engine hoist (1,000lbs capacity), but what you see was all I bought. No motor/trans, no rear frame more that about 2 foot behind the cab, no front axle.
Re: Any idea what this weighs? [Re: RUMBLON] #3143558
05/10/23 02:08 AM
05/10/23 02:08 AM
Is it a D500,D600, D700 or what ?
How many lug studs on the drums and wheels?
