Rally’s gauge bench test #3143024
05/07/23 12:46 PM
05/07/23 12:46 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Needing to bench test a E body rallye oil pressure gauge. I assume you can power it up with a 5 volt source and it should sweep? Am I correct in my thinking. Thanks!
Re: Rally’s gauge bench test [Re: mopar4ya] #3143087
05/07/23 06:54 PM
05/07/23 06:54 PM
Andrewh Offline
Andrewh  Offline
yeah, but the easiest way is to wire 2 AA batteries in series to give you 3 volts.
touch leads to the posts on the gauge and it should go to the middle.
give it a sec as it doesn't react instantly. and then of course swap leads if it doesn't move after a few seconds. lol. always start it backwards, never fails.
Re: Rally’s gauge bench test [Re: Andrewh] #3143095
05/07/23 07:57 PM
05/07/23 07:57 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Re: Rally’s gauge bench test [Re: Andrewh] #3143291
05/08/23 10:17 PM
05/08/23 10:17 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
It takes quite some time for the gauges to react to a stable reading. Also be aware that the gauge should be covered as ambient air flow will affect the reading. If you're not looking for exact readings not so critical. A simple small box with a clear plastic front will suffice. beer
Re: Rally’s gauge bench test [Re: TJP] #3143316
05/09/23 04:53 AM
05/09/23 04:53 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
To test you need to know the resistance of the sender vs pressure. You also have to have a solid feed from the voltage limiter and a good ground. Any one of the three will affect the gauge reading. The Ralle cluster in my 73 Challenger works fine. But both the oil pressure and temp always are on the low side. The senders are what I believe to be from the original engine. Since the tach and fuel level both function properly I assume the ground is correct. Never checked the voltage limiter. Obiviously it functions as the gauges function. But I wonder if there is an issue there. Or maybe ground offset between the block and the cluster. It just came out of storage yesterday. Been like this since I restored it in 2004. Going to dig into it.
Doug
Re: Rally’s gauge bench test [Re: dvw] #3143529
05/09/23 10:14 PM
05/09/23 10:14 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Doug
One can substitute 1/4 watt resistors or a rheostat set to the correct ohms for L M & H readings. This will tell you if it's a sending unit, gauge or ground issue beer
