'70 Barracuda w/'72 grille...want to go back. #3142927
05/06/23 11:00 PM
05/06/23 11:00 PM
ID/MT
Cheeto Offline OP
Cheeto  Offline OP
ID/MT
Have a very early VIN "1000xx" (if that matters) '70 Barracuda that came to me many years ago with a '72-'74 grille and lower valance. I can't blame the previous owner...we're talking mid '90s here so there weren't a lot of budget friendly options.
I'm getting ready to spend some coin on the car now and would like to go back to the correct setup. What am I up against? Past experience tells me that the screw holes in the headlight surrounds don't all match up to the fender but beyond that I haven't dug into it much. The car is about 2 hours away.
Thanks!
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: '70 Barracuda w/'72 grille...want to go back. [Re: Cheeto] #3142976
05/07/23 07:55 AM
05/07/23 07:55 AM
sw michigan
TB3CUDA Offline
TB3CUDA  Offline
sw michigan
header panels are different from 70 to 72,you will need a 70 header panel to mount the 70 grille back in,good part is all parts are reproduced,just cost.the lower valance is the same,you will need just the 70 plastic insert
Re: '70 Barracuda w/'72 grille...want to go back. [Re: Cheeto] #3143012
05/07/23 12:00 PM
05/07/23 12:00 PM
Kirkland, Washington
Pacnorthcuda Offline
Wow! I used to own 100327 that was a 70 with a 72-74 grill. Car was Panther pink. Same car? I had to notch some of the sheet metal in front of the rad to allow the grill plastic to fit. I remember the headlight bezels weren’t exactly perfect either.
I bought the grill for $150 (NOS) back in 1994 when 70 grills were going for $800.
Re: '70 Barracuda w/'72 grille...want to go back. [Re: Pacnorthcuda] #3143019
05/07/23 12:29 PM
05/07/23 12:29 PM
ID/MT
Cheeto Offline OP
Cheeto  Offline OP
ID/MT
Originally Posted by Pacnorthcuda
Wow! I used to own 100327 that was a 70 with a 72-74 grill. Car was Panther pink. Same car? ...
Nope, this is earlier than that.
I was at a Mopar show back then where a restored '70 grille was going for $1500 FIRM. Main grille assy. only, no lower valance.
***Correction: The show I attended would have been early 2000s.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: '70 Barracuda w/'72 grille...want to go back. [Re: Cheeto] #3143257
05/08/23 07:32 PM
05/08/23 07:32 PM
Maryland
MoparMike1974 Offline
Maryland
Yeah, remember when year one had NOS 72+ grills for around $150. I still have one, never been bolted on. Im not certain if the headlight bucket area will be the same as a 72+ vs 70. Both single headlight but you know how 70 is unique everything so I would look into it.
